Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: markymark1 on March 05, 2013, 05:41:31 PM
So here is the deal, I only have a laptop so I see I need a usb stepper controller. I go bargain shopping without even looking at the plugins page. I see a $40 chinese knock off of the mk1 I think to myself thats what I need. Less than a week goes by and there I am opening my brand new stepper controller. It comes with its own gcode interpreter? I cant use that I already have an mpg with mach3 and I love the mill wizard. I dont want to be forced to use a some software that looks like someone wrote the application in like 2 days. I want to use my mach3 software. Problem 1. I cannot return the stepper controller. **********!!!!!!!!! (explicit content) Problem 2 I am not exactly the best computer programmer, I have dont a few easy writes with my arduino but nothing major. Problem 3 I cannot find a plugin already written for this stepper controller. What am I supposed to do? I hope someone can help steer me in the right direction. I have no other choice but to use this stepper controller please help. If your wondering how the circuit is built go to this link and scroll down a little http://www.aliexpress.com/item/USB-CNC-Controller-Interface-Board-4-Axis-Substitute-MACH3-CNCUSB-MK1-USBCNC-2-1/755250419.html
Maybe even help me to just use an already made plugin but change the pins possibly. Idk I just know I need serious help. Im a serious newb at making and setting up a cnc machine I can use the ones I work with pretty well so I thought I would give it a shot. And I need to use mach3 because it is about the closest thing to a conversational program that I can find, mach3 mill plugin is anyways. So please help.
You might try to see if the place you got the controller from would write a plug-in to use it with Mach.
I would lick my wounds Throw the junk in the trash and start over. This time do a little research on the Mach3 site as to exactly what is supported and BUY from the source listed.
The CNC-USB has NEVER been supported by mach3. BUT IF the board will run on the CNC-USB softwqre you WILL like the Software for CNC use.
Probably can even interface your MPG to it as well.
SO those are your 2 main options.
I have the imach!!! m-2 MPG and would like to make it interface to cnc-usb for now till I can figure out how to get my controller to work with mach3 just kind of want to be up and running. I am at a point where I really need to test out the motors and I really need the mpg to work as well. I really cant throw the controller away saving up for one that is compatible with mach 3 is expensive might be able to diy it but thats alot of work maybe in the future but for now just need to be running. I can run gcode through either but I think its kind of crappy for planet-cnc to sell these boards with such crappy software. I mean the main screen looks like something a kindergartner drew. If there is a diy cnc usb motion controller out there I will surely look into it. Bout to google it now. However any advice on getting my mpg to work with cnc usb would be great.
Don't know what version of the CNCusb you tried but it is a nice layout and very usefull. Unless you just HAVE to have gameboy graphics on your screen you should give it a try . Their software is capable of things that MAch3 can only dream of having at this point in time.
A far as I know the CNCusb will never run on mach3, without someone creating a Plugin and I really see no reason to.
IF you need HELP with the pendant I suggest you contact PlanetCNC (;-) THEY are your best option at this point.
Sorry I just noticed you bought a knockoff(illegal )copy of the MK1. I would not expect any help from PlanetCNC (;-).
Back to plan 1 toss it and start over, (;-) TP
I'm pretty sure that the knock off isnt illegal I dont think that cnc usb has an international patent. However instead of trashing anything I think I will just start on a plugin thats what I originally planned on doing. I was just kind of looking for someone to steer me in the right direction to start one.
I think there is an example in the SDK and you may also want to watch the videos. With the release of Mach 4 right around the corner you might want to wait.
I think I may as im sure certain things about mach4 will change as programming often does also I was thinking of maybe making a plugin after i finish my first that adds some conversational programming in the mix. I got a good friend who mightand my cousin too. So hopefully can get this hammered out. First things first learn my c++ language a little bit better. Then I will probably wait for mach4 to comeout..
