Hello
Guest
it is
April 24, 2024, 08:38:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
Some information about port 2
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Some information about port 2 (Read 3965 times)
pedro
5
on:
December 28, 2008, 11:18:44 AM »
hello, as I wish to use some rotary encoders for MPGs, those:
http://it.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=263-2889&x=15&y=10
and I want use port 2 pins 2-9 that are described on manual as CMOS thresholds inputs, I wish to know if it mean have 1 level to 12 volts or 5? If I will use the CD4504 TTL to Mos translator can I assume it will do the work?
Thanks in advance
Last Edit: December 28, 2008, 11:20:46 AM by pedro
Logged
Graham Waterworth
2,673
Yorkshire Dales, England
Re: Some information about port 2
Reply #1 on:
December 28, 2008, 02:53:00 PM »
you should be able to connect this with a 5 volt supply and connect it straight to the breakout board.
Or have a look at these, these work even better
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=15&products_id=30
Graham
Logged
pedro
5
Reply #2 on:
December 28, 2008, 05:54:26 PM »
thank you very much for the help and prompt answer. I realy already have some of the encoders I posted, I will try with them
Logged
Print
Pages:
1
Go Up
« previous
next »
