Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 22, 2013, 11:59:08 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
General CNC Chat
Share Your GCode
CNC Vacuum table project
Pages:
1
Go Down
« previous
next »
Author
Topic: CNC Vacuum table project (Read 10864 times)
GuyFawkes
Active Member
Offline
on:
December 12, 2008, 11:01:05 PM »
Another quickie.
How to make a useful and passable vacuum table from 20 quids worth of acrylic, for a machine with a work envelope of 300 x 150 mm (just scale as reqd) with a holding force of up to 75 Kg
Only tool required (apart from a source of vacuum) is a SHARP 4mm end mill and some acrylic, and time to give your cnc machine a workout.
zip archive contains stl and dxf files, how to, etc etc, again not meant to be a masterclass.
njoy
CNC_Vacuum_table_project.zip
(2308.3 KB - downloaded 2662 times.)
Logged
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Re: CNC Vacuum table project
Reply #1 on:
December 16, 2008, 03:56:18 AM »
Excellent project.
The .rar files caused a bit of agro trying to open but I got there in the end.
Regards, Tweakie.
Logged
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
GuyFawkes
Active Member
Offline
Reply #2 on:
December 16, 2008, 07:22:08 AM »
Glad you're enjoying it.
BTW for you and others, re this and the CPU waterblock and basically everything that I do with acrylic...
The secret with acrylic is the joining, not an adhesive, but a solvent that melts and then welds the two pieces into one. I use Tensol 12 (brand name) but the active ingredient is DMM, or Dichloromethane Methyl Methacrylate.
Excellent how to guide at
http://uk.youtube.com/watch?v=hT6Ow_cBTps
Logged
andreroest
Active Member
Offline
Reply #3 on:
January 04, 2009, 01:06:12 PM »
Guy,
Can you mail me the zip file because I,m very interested but the download remains corrupt.
My email is
ahroest@xs4all.nl
Thanks a lot!
Andre
Logged
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Online
Reply #4 on:
January 12, 2009, 01:27:29 PM »
Quote from: andreroest on January 04, 2009, 01:06:12 PM
Guy,
My email is
ahroest@xs4all.nl
Thanks a lot!
Andre
Andre,
I notice you have a lot of problems with downloading but you blame the file as being corrupt. I just checked this one for you as well and it's perfect.
Possibly you have some sort of security running on your system that will not allow you to download?
Guy, nice work, you're a very giving man with your time. I'm sure I speak for all of us when I say thank you for your input on the forum-
Logged
Dave->
Garyv
Active Member
Offline
Reply #5 on:
July 14, 2009, 04:27:19 PM »
Guy I also sent you a PM with the same question just in case you havent been around in a while, also someone else might know the answer here as well.
My question is about the vacum that you can use with the vacum table i amd building a new router and want to add a vacume table to it as soon as I get it running..Is there enough flow if I where to use an A/C service vacume pump?
I know it will pull down to -30 vacume but will the volume be enough to get the material to start to pull down, I have heard a lot of people use a big shop vac for their table but I dont want to hear that run for hours either and an A/C vacume is really quiet running.
THanks
Gary
Logged
GuyFawkes
Active Member
Offline
Reply #6 on:
July 14, 2009, 04:32:03 PM »
Yes, use an edwards type vacuum pump, not a vacuum cleaner.
just use some neoprene rubber to cover all the holes in the vacuum table not covered by the part
holding force = no of holes covered by part (area) x vacuum
vaccum pump, even knackered one, will pull 13/14 psi vacuum easy, shop vac may pull 5, and will then overheat because the use the airflow to cool the motor usually
HTH etc
Logged
Garyv
Active Member
Offline
Reply #7 on:
July 14, 2009, 04:38:48 PM »
Excelent,, I have some .750 starboard that I am going to use for a vacume table and cut the slots in it for the o ring material..
I want to start cutting out slot car tracks believe it or not..
Some tracks are going for BIG BUCKS just need to use the right material and needs to be held perfectly flat to the table...
THanks for the information..
Gary
Logged
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
G-Code, CAD, and CAM
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
Third party software and hardware support forums.
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
