Hello Guest it is April 20, 2024, 12:24:36 AM
Author Topic: Brian's Emco Compact 5 Retro  (Read 103594 times)
Offline Bengt
  •  54 54
    • Private CNC site
Re: Brian's Emco Compact 5 Retro
« Reply #40 on: September 25, 2009, 06:01:06 PM »
Hi Dan,
Sorry to say but I have never seen Emco ATC that is solenoid driven, the one I have been playing with is DC driven with toolchange rotation clockwise seen from the chuck and locking counterclockwise with a ratchet/pawl. If you have the original mechanics I suggest you stay with the original setup as intended as you will get problems with the gearing ratio so the stepper will probably not hold the tool in position without mechanical aid = reversing - using the ratchet/pawl for locking up the tool in position.
The macro was written for PC-Turn 50 so it is possible that you have to modify the code. Sorry to say I do not have the lathe anymore so I cannot not help you on this.
The DC motor goes full voltage clockwise and reduced voltage with polarity change in reverse as it holds the tool in position all the time it is powered up, this is how it works on the PC-Turn 50.
Hope this helps
Cheers Bengt
Bengt
« Reply #41 on: September 25, 2009, 06:53:51 PM »
Do you know what the voltage and current requirements are for the dc motor?
« Reply #42 on: September 25, 2009, 07:27:18 PM »
Hi Dan,
I believe it is 24V. I should have a schematic for the toolchanger somewhere.
Cheers,
Peter.
« Last Edit: September 25, 2009, 07:42:30 PM by Peter Homann »
Homann Designs
http://www.homanndesigns.com
« Reply #43 on: September 25, 2009, 10:51:24 PM »
Thanks. Looking forward to seeing that schematic.
Hi Dan,
Cheers,
Peter.
« Reply #44 on: September 26, 2009, 12:28:55 AM »
On my Emco Compact 5 it is a 12VDC motor. I used two relays to switch the power polarity to the motor in correspondence to a signal from Mach3. The reverse polarity being simply fed through a resistor. I used a slotted disk on the back of the turret shaft and an optical sensor to count the tools, and I have simple macro to control this.
Daniel
« Reply #45 on: September 26, 2009, 01:11:36 PM »
 You are correct. I checked the toolchanger with a 9V battery and I see that it runs one way into a stop and the other way continuously. There are no other wires for sensors to determine what position the tool changer is in. So it looks like I would have to add the optos.
Thanks for the info. Would you please email me the macro you used for the tool changer and do you have a schematic of how you set up the two relays?
TIA
« Reply #46 on: September 26, 2009, 02:13:44 PM »
Dan,
Tell me to which email address you want me to send you the macro.
Daniel
« Reply #47 on: September 26, 2009, 02:26:35 PM »
Email the macro to dmauch@seanet.com
Thansk I appreciate this.
Dan,
Daniel
« Reply #48 on: September 26, 2009, 02:59:39 PM »
Just emailed it to you.
Daniel
« Reply #49 on: October 06, 2009, 12:24:43 PM »
Hi to all,
I think I am Dan customer. Anyway if I am not, I am in the same position. I do have that kind of lathe with tool changer and I want to retrofit to be driven by Mach3.
I intend to use one of Dan units (G540). What else do I need?
Seems the biggest problem it is that motor on tool changer. What do you guys recommend in order to have a proper working machine?
RGDS
Gabi
