Hello Guest it is May 10, 2024, 10:23:37 PM
Author Topic: Mach XML Reader  (Read 129128 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #10 on: November 20, 2008, 04:01:48 PM »
Thanks Rich!
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #11 on: November 20, 2008, 04:02:21 PM »
It might be a bad download, try to delete the folder and redownload.
If this doesn't resolve it move it off the desktop and let me know if that works.
Re: Mach XML Reader
« Reply #12 on: November 20, 2008, 08:17:42 PM »
Thanks zealous,
It seem to work if I download the zip on the desktop and run the XML Reader from within the zip file. If I either extract the file to the desktop it does not work anymore.
If I download the zip into a subdirectory Mach2\Mach_XML_Reader it does not work neither in or out of the zip.
Gaston
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #13 on: November 21, 2008, 01:06:48 PM »
Hi Gaston,
Wow that sounds strange.
I’ve had it tested on Vista and XP and had a few people double check it for me.
It sounds like it can't find the programs icon, but it’s strange that it works if put in different location  ???
« Last Edit: November 21, 2008, 03:03:29 PM by zealous »
Re: Mach XML Reader
« Reply #14 on: November 21, 2008, 02:28:49 PM »
Excellent program. Makes changing XML's even easy for a moron like myself -  ;)
Thank you!
Re: Mach XML Reader
« Reply #15 on: November 21, 2008, 02:30:17 PM »
Hi Zealous,
I saved the zip file in a subdirectory of Mach. Then I extract the file in the same directory.
The program may work some time, maybe twice in a row, but most of the time only the logo appears and briefly I can see an error box then it goes behind the logo and I cannot reach it to close it. The only way out is to terminate its execution with Windows task manager.
On the other end, if I save and extract the file on the desktop it never failed after 5 or 6 tries.
Gaston
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #16 on: November 21, 2008, 03:01:50 PM »
Gaston,
I am not getting any reports of issue with the program from others, so I am quessing it is something specific to your system.
Try to download the XML reader without it being Zipped as well as I shortened the name and removed the splash screen:
If that doesnt work you may have a problem with your browser, repair it or reinstall:
http://support.microsoft.com/default.aspx?kbid=318378
« Last Edit: November 21, 2008, 03:49:54 PM by zealous »
Re: Mach XML Reader
« Reply #17 on: November 21, 2008, 03:27:53 PM »
MachCML.exe opens properly everytime whereever I saved it  :)
If you wish to investigate some more I can do more test.
Gaston
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Mach XML Reader
« Reply #18 on: November 21, 2008, 03:33:53 PM »
Gaston,
Thank you for testing
If this one works, then is the name convetion I used  ::)
And in some system might not like more then 8 characters in the name.
http://alphagraphicdesigns.com/artsoft/MachXM2.zip
Re: Mach XML Reader
« Reply #19 on: November 21, 2008, 03:52:42 PM »
Jason,
The last version MachXM2.zip works fine.
You may be right it is a matter of naming but not name length because I copied    Mach_XML_Reader_2.exe     into     Copie de Mach_XML_Reader_2.exe    and it works fine :o.
Gaston
