May 23, 2013, 09:46:40 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Flash Screens
| | | |-+  Function to get a number from a string!?
Pages: 1   Go Down
Print
Author Topic: Function to get a number from a string!?  (Read 2852 times)
azambuja
Active Member
Offline Offline
View Profile
« on: October 15, 2008, 10:06:08 AM »
Hello friends!!!
I need to count the numbers of letters of a _root.something (exemple: String="something" to get Number=9, or something like that) and with this number I can use it in a If condition.
Thanks for your supply.
Azambuja
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: October 15, 2008, 10:31:29 AM »
Try:
mystring = "something"
X = LEN(mystring)
X should be 9.
You might be able to just do:
X = LEN("something")
azambuja
Active Member
Offline Offline
View Profile
« Reply #2 on: October 15, 2008, 10:58:26 AM »
Hey man!!
Thanks but it does not work. Maybe I am not using it in the right way.
Azambuja
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #3 on: October 15, 2008, 12:43:08 PM »
Is it case sensitive? Try Len and not LEN? That's the VBA function. Maybe the script function is different. I'll have to check the docs.
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #4 on: October 16, 2008, 02:29:39 AM »
I think he meant in Flash and not VB
This will return the number of your strings length:
Code:
MyString.length
this will check to see if the digits are 9:
Code:
if (MyString.length == 9) {
trace("Is 9");
} else {
trace("Is not 9 it is:"+ MyString.length);
.....but you can take the code they gave for VB  and run it in flash but you have to do it like this and I dont belive you can split and join in Mach's VB
fscommand("VBMacro" "some VB here")
« Last Edit: October 17, 2008, 03:29:04 AM by zealous » Logged
Regards, Jason Blake
www.Fusioncnc.com
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #5 on: October 16, 2008, 08:09:10 AM »
Oops, didn't see that it was in the Flash section. Smiley
Thanks Jason
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #6 on: October 17, 2008, 03:27:02 AM »
NP  Smiley
www.Fusioncnc.com
azambuja
Active Member
Offline Offline
View Profile
« Reply #7 on: October 17, 2008, 06:43:37 AM »
Thanks Zealous!!
That worked. Now I can continue to work.
Azambuja
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
