I was using Mach 3 to convert my DXF files to G code but when I get the g code file and try to run it on Mach 2 I still have the missing arcs from the part I want to cut any idea?? I know I should be using Mach 3 directly but I cannot makeit run with my machine when I set it up is so different from the Mach 2 Pin and ports setup that I tried my best but I haven´t been able...
Hope someone can help.
Roberto
