Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 21, 2013, 02:13:27 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Problems threading on the lathe
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
Go Down
« previous
next »
Author
Topic: Problems threading on the lathe (Read 79127 times)
neptune
Active Member
Offline
Re: Problems threading on the lathe
Reply #710 on:
November 26, 2009, 11:49:38 AM »
Last message should read status is same as messages 704 and 706. The RPM indication is working correctly but spindle start problem remains.
Peter
ART
Administrator
Offline
Tough as soggy paper.
Reply #711 on:
November 26, 2009, 12:06:21 PM »
thx peter. Ill check it out.
Art
mayhugh1
Active Member
Offline
Reply #712 on:
November 27, 2009, 01:44:37 PM »
Peter,
Did you check to see if if threading now works or if it hangs looking for an index pulse? - Terry
neptune
Active Member
Offline
Reply #713 on:
November 27, 2009, 03:23:34 PM »
I didn't get a chance so far due to work commitments, but I will try it tomorrow and post findings here.
Peter
neptune
Active Member
Offline
Reply #714 on:
November 28, 2009, 10:29:24 AM »
I tested threading today with the special version of .32 attatched to Art's post number 703, using the simple threading wizard.
At first the spindle would not run at the speed programmed in the wizard and I was getting an error message "Scripter Compile Error. In: Spindle Speed.mis" Could not resolve this, so reloaded version 042.020 and ran threading wizard succesfully.
Reloaded special version of .32 and tried threading wizard again. This time spindle speed was as programmed with no error messages.
Threading program ran OK but the pitch was incorrect. Further investigation showed that the pitch varied with spindle speed. Testing with a pitch of 1 mm the following feed rates were noted:
RPM 600, Feed 0.31 mm/rev
RPM 200, Feed 0.72 mm/rev
RPM 100, Feed 0.98 mm/rev
Z axis velocity is set at 1000mm/min
At 100 RPM the feed rate was unstable and the Z axis motor could be heard to be continuously hunting.
During testing, the programmed spindle speed, indicated spindle speed and measured spindle speed (tacho) were all within 2 to 3 RPM.
During threading the tool engaged correctly during each pass (although at the wrong pitch) except at 100 RPM where the fluctuating feedrate destroyed the thread.
Peter
ART
Administrator
Offline
Reply #715 on:
November 28, 2009, 12:54:42 PM »
Hi Peter:
Hmm. Ill check this out. What was the G76 line you used. That pitch seems strange.. cant figure what its related to.
Better yet, can you try 600rpm again, and then p[ost whats in the lasterrors.txt file.. Itll tell us why the pitch was wrong..
Art
ART
Administrator
Offline
Reply #716 on:
November 28, 2009, 01:37:11 PM »
Peter:
My appologies, I think I may have found the problem, I had forgotten your machien was the fast one that overwrote the neg bit in the timer.
I found the correction had to be fixed up for that as well. It may explain the pitch error. Try this version and let us know what happens.
Thx
Art
Mach3Nov29.zip
(1161.82 KB - downloaded 99 times.)
neptune
Active Member
Offline
Reply #717 on:
November 29, 2009, 06:17:12 AM »
Art
It looks good.
I cut 4 threads today as follows:
1.75mm pitch at 600 RPM
1.25mm pitch at 200 RPM
1.0mm pitch at 400 RPM
0.5mm pitch at 100 RPM
Spindle RPM and pitches were correct as programmed and were stable. 1.75mm pitch was gauge perfect, the others fitted nuts well (no gauges available) Threads look good, everything ran smoothly.
Thanks for your help on this.
Peter
Global Moderator
Offline
Reply #718 on:
November 29, 2009, 07:51:22 AM »
Peter,
Save me some reading. Can you post your XML so i can see your configuration?
ART,
I assume that this fix doesn't affect threading when setting the rpm manualy?
neptune
Active Member
Offline
Reply #719 on:
November 29, 2009, 10:48:28 AM »
Rich
XML attatched as requested.
Peter
turn 3.xml
(147.03 KB - downloaded 83 times.)
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
