Hello Guest it is April 26, 2024, 07:27:50 AM
Author Topic: Problems threading on the lathe  (Read 435283 times)
Re: Problems threading on the lathe
« Reply #320 on: May 23, 2009, 03:45:43 PM »
I hooked up an external 5v supply to the ss and set the jumper but I still keep having a problem every 5 minutes to 1 hour where my spindle speed drops to 78 rpm and mach freezes completley. I can open device manager and SS is still present under USB but Mach will not respond.
I can force mach to close and i get the error reporting pop up , below is what it says
szAppName : Mach3.exe     szAppVer : 1.0.0.1     szModName : hungapp
szModVer : 0.0.0.0     offset : 00000000
When I click the more details box I get the message below
C:\DOCUME~1\Owner\LOCALS~1\Temp\WER92ee.dir00\Mach3.exe.mdmp
C:\DOCUME~1\Owner\LOCALS~1\Temp\WER92ee.dir00\appcompat.txt
When I force mach to close and then reopen it I get the error message stating that SS is not connected , to close mach , unplug and replug usb to SS and restart Mach.
Any thoughts on whats going on?
« Reply #321 on: May 23, 2009, 03:49:41 PM »
Can you look at the SS monitoring page when you are aving problems or are you not able to do that?
« Reply #322 on: May 23, 2009, 03:51:36 PM »
cant do anything in mach when the problem occurs
« Reply #323 on: May 23, 2009, 03:54:22 PM »
Have you got more than one SS plugin in the plugins folder? If so delete the older ones.
Make sure its the latest plugin you are using.
« Reply #324 on: May 23, 2009, 04:00:52 PM »
Just one , its the latest one from the warp site
« Reply #325 on: May 23, 2009, 04:40:32 PM »
Not sure what to suggest as if Mach is crashing then its hard to find out if the SS is losing it or if its something else.
 Would be interesting if you could go back to the PP and see if everything is stable.
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
« Reply #326 on: May 23, 2009, 04:46:38 PM »
Hi:
  The error messages dont really tell much because your forcing it to close.
Is it totally unresponsive in all aspects, can you trigger an Estop for example?
  It should be near impossible for MAch3 to lock up when not using the printer port.. unusual at least.
I would delete all files in the plugins folder except the smoothstepper.dll and see if that helps.. It may be some
other plugin causing the lockup due to some bad interaction. Worth a shot anyway.
Art
« Reply #327 on: May 23, 2009, 05:24:05 PM »
Totaly unresponsive, The hour glass pops up as the pointer and nothing can be clicked, estop does nothing. Its as if its lost comm with the smooth stepper and its waiting .
Forcing Mach to close leaves the spindle turning and coolant on , juast as it was when the program locks. I can then walk to the back of the machine and unplug the SS and the spindle and coolant will stop.
After it locks and I close mach I have to unplug and replug the SS board before Mach will connect with it again.
I have moved all the plugins other than SS to a temp folder , will run it the rest of the day and see what happens
« Reply #328 on: May 23, 2009, 05:29:07 PM »
Ran about 20 seconds this time, I was just manualy jogging with spindle on  . Hourglass cursor is up , spindle is turning around 80 rpms . Estop button, cycle start , pause have no effect. Cant click anything in mach either .
« Reply #329 on: May 23, 2009, 05:31:15 PM »
Have a look at CPU useage and see whats there. Any Brains or macropumps?
