Hello
Guest
it is
April 25, 2024, 04:30:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problems threading on the lathe
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
Go Down
Author
Topic: Problems threading on the lathe (Read 435140 times)
panaceabeachbum
338
Re: Problems threading on the lathe
Reply #20 on:
September 26, 2008, 10:48:13 PM »
smooth stepper landed today , the first one had male db25 and plugged right into my c11 BOB , This one came with female db25 on the cables, will have to figure something out in the morning to plug it into the c11 BOB on the lathe.
Brett and Hood stay tuned, many stupid questions to follow
Logged
www.thompsonmachine.net
Overloaded
4,922
Reply #21 on:
September 29, 2008, 11:27:56 PM »
Hey RT,
Would you mind to check this for me ?
http://www.machsupport.com/forum/index.php?topic=8461.new#new
If this is the screen that you are using.
RC
Logged
Rieks
26
Reply #22 on:
February 22, 2009, 04:23:11 PM »
Hello all,
While treading on the lathe, the x-axis is walking slow in or out on some cuts
Can some one tel me what the solution is?
Rieks
Logged
Carnoustie, Scotland
Reply #23 on:
February 22, 2009, 04:53:57 PM »
What is the code you are using?
Logged
Reply #24 on:
February 22, 2009, 07:22:50 PM »
What version of MACH are you using?
How are you generating the threading code? Wizard, M76, G32?
What is the condition of your lathe?
- Ball screws / steppers / backlash ?
What are you using for an index?
Logged
Rieks
26
Reply #25 on:
February 23, 2009, 08:29:38 AM »
Hello,
The version I use is R3.042.020 and I use the wizard "Threading" in Lathe, thus G76
Logged
Reply #26 on:
February 23, 2009, 08:32:50 AM »
and what is the code that gives you the problem?
Logged
Rieks
26
Reply #27 on:
February 23, 2009, 10:30:23 AM »
When treading, after 2 or 3 cuts, wit a depth of 0.2 mm, befor the next Z-axis movement in negativ
direction, the X-axis feeds in 0.2 mm, and then, when Z-axis moves in, the X-axis moves slowly out, as if
a taper is cut.
Rieks
Logged
Reply #28 on:
February 23, 2009, 10:47:03 AM »
please give an example of the problem code.
Logged
Rieks
26
Reply #29 on:
February 25, 2009, 03:28:13 PM »
Hello Hood,
sorry for the delay, Here is the problem code.
It is the first time I tested the threading wizard.
Rieks
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
Go Up
« previous
next »
