Hello Guest it is April 25, 2024, 05:46:01 PM
Author Topic: Problems threading on the lathe  (Read 435160 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Problems threading on the lathe
« Reply #160 on: March 19, 2009, 11:16:12 AM »
Hi, Brian
I know your busy, Could you post the updated .exe "Art" was talking about above, So we can continue testing.
Thanks, Chip
« Reply #161 on: March 19, 2009, 05:53:26 PM »
CHIP,
Reply #152.
Offline Chip
  •  2,055 2,055
« Reply #162 on: March 20, 2009, 03:48:38 AM »
Hi, Rich
Thanks for the Info, But I was looking for the update exe for 3.042.023 that Art implied Brian would post with the latest Fix's he made.
After testing there are a few differences in Art's exe  as he stated earlier and I was just wanting to continue testing with a version that had only mod's that addressed the threading Fix's.
Thanks, Chip
« Last Edit: March 21, 2009, 12:54:54 AM by Chip »
« Reply #163 on: March 21, 2009, 09:40:16 PM »
Chip,
ver 3.042.023 is available for downwload. Get to work trying it out.  ;D
Thanks for the update Brian.
« Reply #164 on: March 21, 2009, 10:54:19 PM »
Dear Brian and ART,
I just tried out threading with the updated ver 3.042.023 with the SS using G32 or G76.
No joy! Etremely sensitive to a change in rpm on my few tests.
I didn't try the PP.
With only a 10 rpm change ( 400 dn to 390 ) the threading cycle faulted.
When it faults the XZ go  "wild". Also you get the error
"NO SPINDLE FEEDBACK SEEN IN G95"
Ah.....i need to remember what our good looking Scout mom said:
"IF at first you do not succeed, try, try again"  :)
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
« Reply #165 on: March 22, 2009, 12:05:04 AM »
Rich:
 If you can, try PP for me, SS uses different code for the most part. If PP fails, then we'll know its a difference form Brians code to mine.. since mine works in your tests..
Thx
Art
« Reply #166 on: March 22, 2009, 01:32:08 PM »
ART,
MACH VER 3.042.023
When i use the SS the rpm is displayed correctly ( 0-1300 RPM within one or two as measured ).
When i use the PP the rpm is off and over 130 rpm it's useless.
The same happens if i replace the ver .023 mach.exe, with the one from .020, and the 17-2 ( only pp use).
This is true for 2 different pc's.
Since I  can't get the PP to correctly display the RPM properly, someone other than myself needs to test using the PP.
Offline ART
  •  1,702 1,702
« Reply #167 on: March 22, 2009, 02:50:33 PM »
Rich:
 Ahh, OK, so I take it the encoder index is just too short for the PP to read, so yours is only usable on the SS..
Did any PP version work on that machine?
Art
Offline ART
  •  1,702 1,702
« Reply #168 on: March 22, 2009, 06:44:29 PM »
Rich:
>>Dear Brian and ART,
  Sorry, my bad, Brian tells me the fix isnt yet released on the web, so this test doesnt mean much. :)
Thx
Art
Offline ART
  •  1,702 1,702
« Reply #169 on: March 22, 2009, 08:30:18 PM »
