Hello Guest it is April 26, 2024, 09:51:21 PM
Author Topic: right click in mach screen  (Read 7442 times)
« on: September 10, 2008, 08:01:04 AM »
Another question, can I disable the mouse right click when running a flash screen in mach3.
Because this can interfere the user.
thanks
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: right click in mach screen
« Reply #1 on: September 10, 2008, 06:52:35 PM »
Hey,
To remove Content:
Code: [Select]
var rootMenu = new ContextMenu();
rootMenu.hideBuiltInItems();
_root.menu = rootMenu;
Another way to  Remove content:
Code: [Select]
Stage.showMenu = false;
Right click detect:
Code: [Select]
onEnterFrame = function () {
if (Key.isDown(2)) {
trace("Your right clicking")
To add to the "Right Click" menu system(also including functions):
Code: [Select]
Right Click Menu
var myMenu:ContextMenu = new ContextMenu();
myMenu.hideBuiltInItems();
var Load_menu:ContextMenuItem = new ContextMenuItem("LOAD GCODE", load_fun, true, true, true);
var edit_menu:ContextMenuItem = new ContextMenuItem("Edit GCODE", edit_fun, false, true, true);
myMenu.customItems.push(Load_menu,edit_menu);
_root.menu = myMenu;
function load_fun() {
fscommand("Button", "216");
function edit_fun() {
fscommand("Button", "115");
Jason Blake
