Jason totally Rocks!
I have added a blerb of script to do the movements, and (amazingly), it worked!
Since this is running as a macropump and goes through and then restarts, it isn't necessary to have logic for stepping through the spots in sequence, all that has to be done is just move X + 9 unless the end of a row has been reached. This is easly figured out based on the number of files.
If anyone has comments please let me know, otherwise I'll put it on the actual machine today and see what happens.
----------------------- (code below - I coudn't figure out how to make the 'code' box)
'for all cases not described in select below set move to be X+9
MoveX = GetOemDRO(800) + 9
MoveY = getoemdro(801) + 0
'for the special cases at end of rows override previous settings
Select Case GetFileCount
Case 12
MoveY = getoemdro(801) - 9
MoveX = GetOemDRO(800) - 99
Case 24
Case 36
Case 48
Case 60
Case 72
Case 84
Case 96
MoveY = getoemdro(801) - 63
end select
'Move Y
Code ("G1 Y" & MoveY)
'Move X
Code ("G1 X" & MoveX)
