Hello Guest it is April 24, 2024, 01:17:45 AM
Author Topic: Microstepping & Torque  (Read 11139 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
« on: August 31, 2008, 08:28:34 PM »
I can't really find any clear information on the effects of microstepping and torque, right now I have my board set for 8 microsteps (jumper selectable) just happened that way as I was careless reading the settings. I have been just getting set up but last night I had to mill off some fins on the heatsinks I was making and the machine groaned and jammed a couple of times. So I am wondering if I should pop another jumper or two and go to 1/4 step or 1/2 step or even full step mode? Seems from what I have been able to find microstepping will not improve resolution and may actually make it worse if it takes a few bumps to get the motor to move or switch direction.
Kristin
Re: Microstepping & Torque
« Reply #1 on: August 31, 2008, 09:10:46 PM »
Kristin,
    Yes, microstepping will reduce torque somewhat.  But, if you're having problems with the motors stalling, your real problem is that either:
a) You're pushing the machine too hard or,
b) Your motors are too small or,
c) Your controllers are not very good, or are limiting current (Geckos are highly recommended) or,
d) You're not running high enough power supply voltage or,
e) Any combination of the above
   What kind of machine is this?  What size motors?  What, if any reduction (including leadscrew pitch)?  What stepper controllers are you using?  What is your power supply voltage, storage, curring capability?
Offline Kristin D
  •  203 203
« Reply #2 on: August 31, 2008, 09:33:03 PM »
Questions, questions...
It's a Taig mill, motors are 205 Oz unipolar, HobbyCNC Pro driver board (hey for $25 on eBay I couldn't pass it up), 20TPI leadscrews & adjustable nuts (new a couple of weeks ago). I think you hit it with supply voltage, think I am only getting about 20 VDC @ 10A  out of the gutted Astron PS I am using, got to dig out another transformer and build another for 30-32 Volts I can run the board up to 42VDC but don't have a transformer on hand with 36V output.
I have adjusted the gibs, adjusted the leadscrew nuts and it's not mechanicaly binding anywhere, really not trying to run fast(6 IPM) or take more than .01/cut with a sharp USA made four flute 3/8"end mill. Could just have been the heatsink was pretty soft aluminum and was giving me fits?
Kristin
« Reply #3 on: August 31, 2008, 09:36:13 PM »
Kristin,
There are books written on the subject of microstepping. And if you want to be mathematicaly challenged read some of them. If i remember correctly microsteps only uses a small portion of the current available to hold position and max current is available at the 1/2 or full steps. But the controller, motor, wiring etc can greatly influence the torque at the microstep
location. I tested on some small steppers ( < 100 in oz ) using a torque gage and found that you could break the holding torque at a microstep position ( don't know what microstep position it was at) using less torque then at say a full step postion ( if thats where it was). When it skipped it will seek one of those postions and maybe it took 50-60% less torque as compared to breaking the hold at a major position.
Theory is interesting but on the practicaly end..........
I watched my  200 oz in steppers on the mill cut right thru a 1/2"  hardened steel clamp at 1/4" deep  and break the 1/4" carbide end mill at the end and they never missed a step! I was able to return to 0 location and could repeat if stupid enough to do so! ;D The engraving machine will  split .001" easily into ten or 20  parts using 10 or 20 steps jogs, but then the resolution is coming from the axis mechanics. Frankly it's very hard and time consuming to attempt to measure inaccuracy of a microstep.
That said I'll stick with the microstepping / smoot running and tune and use the motors appropriately and leave the books on the shelf.
Also some of the testing which I tried.
 ;) RICH
« Reply #4 on: August 31, 2008, 09:54:47 PM »
Kristin,
Find where the steppers start to skip. Back acceleration down to 60 or 70%of where they started skipping. Make some test cuts in material and see  if you left enough of a margin in the settings for cutting.  Of course, like Ray noted,
the tuning and capabilites change with electrical supply available.
What you really want is power and that is achieved by the combination of speed and torque. If you had a motor curve
you could get in the ball park rather quickly. Even with or without a motor curve some testing will pay dividends.
Offline Kristin D
  •  203 203
« Reply #5 on: August 31, 2008, 10:11:22 PM »
Kristin,
Rich,
I think the problem is really my power supply plenty of amps but low by 1/3 to 1/2 the rated voltage. Or it could have just been the dead soft aluminum didn't like being cut, the other day I was cutting some acrylic with a 1/8 mill and it took the end off of the 1/8"x1" steel hold down strap without a cough or hicup proabably a .05 slice full depth!
Kristin
« Reply #6 on: August 31, 2008, 10:20:41 PM »
Kristin
Kristin,
    OK, well you've got several things working against you.  Unipolar motor controllers, and low supply voltage.  The motors and drivers are probably OK for such a small machine, however.  I'd beef up the power supply - get as close as you can to the 42V limit, and you'll see MUCH better performance.  At 20V, your performance will be very poor.
    You do have to be careful with soft aluminum, as it gets "gummy" and will really clog the cutter.  Using a good lubricant will help a lot.  WD-40 works pretty well.  Also, don't go too high in RPM.  You're far better off keeping RPM low, and increasing feedrate.  Excessive RPM creates a lot of heat, which will tend to clog the cutter, as well as dulling it much faster.
    Good luck, and let us know how you make out!
« Reply #7 on: August 31, 2008, 10:34:51 PM »
MY NOTES ON DESIGN OF A POWER SUPPLY:
4 to 20x motor voltage ( GEICO DRIVE RECOMENDATIONS) [ of course stay within limits of your drive]
< 4X  drive won't run smoothly
> 20X motor heating
OVERDRIVE RATIO ? - 25:1 power supply voltage to motor rating ( similar to 4 to 20 above )
POWER SUPPLY AMPERAGE: should be greater the all drive requirements
Others may want to commnet on the above, but believe they are good quidelines.
BTW, when cutting heat sink or other AL which was anodized, that surface is harder than you think.
Offline Kristin D
  •  203 203
« Reply #8 on: August 31, 2008, 10:41:44 PM »
Thanks Ray,
I did use WD-40 (actually Walmart spray oil or "SPROIL" as I am fond of calling it) but I think your right about the voltage, I have to tear the cover off of one of these wheelchair chargers I have here and check the transformer voltage, I recall something like near 30V output when I was charging a couple of batteries in series, I just don't remember if it had any internal filtering except the regulator board. That would give me a 25% boost in power right there and I can hunt down another transformer later.
Kristin
« Reply #9 on: August 31, 2008, 10:52:10 PM »
Kristin,
    Put lotsa capacitance on whatever you use.  I would think you'd want 10,000 uF at an absolute minimum, so you don't get voltage sag under heavy load.
