Hello Guest it is March 28, 2024, 10:48:41 AM
Author Topic: Plugins wishlist. ( Please add your own to this list )  (Read 20778 times)
Offline CncBr
  •  36 36
    • CNCBR
Re: Plugins wishlist. ( Please add your own to this list )
« Reply #20 on: August 10, 2006, 10:18:49 PM »
Hi Fernando,
With this his idea Works!
But with together Mach you could put any motor type!
I did exactly as the drawing, My Hardware captures the position and speed and command the mach to move.
Regards
Junior
Offline CncBr
  •  36 36
    • CNCBR
« Reply #21 on: August 10, 2006, 11:08:21 PM »
HI Fernando
I forgot to comment on this hardware that I developed is not specify for his cyborg is for a scanner 3D of low cost!
I only hitchhiked of the idea of the arm, and I thought further on.
Now vein such a simple idea for his  cyborg that you won't spend more than U$5 for axis hauls of the price of the encoder and of the motors, Excuse but I only woke up now for this detail!
Tomorrow I send the solution.
Best Regards
Junior
« Reply #22 on: August 24, 2006, 07:05:45 AM »
Is there any plans for an integrated version of keygrabber as a plugin with Mach as opposed to a seperate executable? I think this would tidy things up nicely.
If this is likely to happen can I make a request. Instead of mapping the pendant button to keystrokes, can we have the ability to map them to buttons on the screen - i.e. press pendant button then click on the screen button you want to assign - that would be nifty!!!
« Reply #23 on: August 24, 2006, 12:06:04 PM »
Hey Junior,
It is good to see that you got it working. I would think a good use would be to teach machines, such as robotic arms to do things like paint, weld, cut, things like that.
How can we get our hands on the hardware and plugin?
Do you have pictures? videos?
Best Regards
Fernando
Offline CncBr
  •  36 36
    • CNCBR
« Reply #24 on: August 31, 2006, 01:01:29 AM »
Hi Fernando/Dave
Excuse the delay in the answer, I had out last week!
Yes I am working in the plugin. I think inside + - in 2 weeks it should be ready.
Today I received definitive Card of the interface.
I still don't have the videos that I am producing an an arm of 6 axes.
I made the initial tests with the encoders in a direct machine in the motors to simulate
Verry Best Regards
« Last Edit: August 31, 2006, 01:03:18 AM by CncBr »
Junior
« Reply #25 on: August 22, 2007, 01:18:18 PM »
Hello,
Is there any progress in developing this movement recording ...
Just curious,
Kris.
Logic takes you from A to B, imagination takes you anywhere
Offline CncBr
  •  36 36
    • CNCBR
« Reply #26 on: August 22, 2007, 08:16:44 PM »
Hi Kris,
Yes, the hardware this ready one only lack to finish the plugin for mach3.
6 axes to capture in real time.
Can digitizes the positions or to move her Machine as in real time.
Great hug
Junior
« Reply #27 on: August 23, 2007, 11:18:29 AM »
Hello,
Are you gonna write this plugin, or is someone else doing this.
Do you sell this hardware, once the plugin is finished, or will you make it able to download all the schematics ,the  microcontroller program, etc.
I'm not in direct need of this, but reading this post gave me some idea's.
Greetz,
Kris.
Offline CncBr
  •  36 36
    • CNCBR
« Reply #28 on: August 23, 2007, 10:42:47 PM »
Hi Kris.
Yes I will sell the hardware with plugins, and the price will be very cheaply, that can help a lot of people to do Machines and it does tie deficient physical.
I have hardware for everything that you need BREAK-OUT, TECLADO EMULADOR, DRIVE OF MOTOR (STEP MOTOR) (SERVO DC) (SERVO BLDC) and THC
I am here with priority to finish a Plugin to program my drives for the MACH3, it will be the first to be programmed direct for the mach and with status in real time.
This is next priority.
I thank his interest, of my insomnia nights it was not in vain.
Best Regards,
Junior
« Reply #29 on: October 18, 2007, 09:38:23 PM »
not sure if this is the right place but what about a 360 controller plugin to use as pendent?
