Hello Guest it is November 13, 2026, 04:09:13 PM
Author Topic: Attaching wave file to button  (Read 18276 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« on: June 06, 2006, 05:20:17 AM »
I thought I'd post this here for the screen designers.
If you'd like to attach a wave file to a single state or multiple state button use the code provided.
1. In screen designer you'll change your button to "VB",
2. then in Mach 3 you'll apply the button comand and the wave file code.
3. All you have to do is change the directory of your wave files or the directory in the code.
*Example:(sndPlaySound "C:\WINDOWS\MEDIA\tada.wav", &H1)
Here is the basic function code to call on a wave sound placed on a button:
Public Declare Function sndPlaySound Lib "winmm.dll" Alias "sndPlaySoundA" _
    (ByVal lpszSoundName As String, ByVal uFlags As Long) As Long
    sndPlaySound "C:\WINDOWS\MEDIA\ding.wav", &H1
Here is the code to place on the "Display" button(This is a two state button with two diffrent state sounds!)
value = GetParam("Boundry")
If  value = 1 Then
'SetButtonText " Job "
SetParam "Boundry" , 0
 Else
SetParam "Boundry" , 1
'SetButtonText "Machine"
End If
 >:( Currently I haven't found the code to trigger a wave sound for the E-Stop, need some help ;D
« Last Edit: June 06, 2006, 06:03:14 AM by zealouse »
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Attaching wave file to button
« Reply #1 on: June 06, 2006, 06:52:15 AM »
If you need to find good sounds to add to Mach look here:
http://www.findsounds.com/ISAPI/search.dll
All sounds are free and the search engine is great, best I've seen.
