Hello Guest it is April 25, 2024, 04:34:27 PM
Author Topic: USB connection problem  (Read 3081 times)
« on: August 11, 2008, 10:24:14 AM »
Every once and a while I will get an error saying the smoothstepper has lost comunication with USB and you must unplug and replug in the board in and restart mach 3
I switched computers and it still does it ?
I have 2 boards and both are doing it ?
HELP!!
Curtis
Re: USB connection problem
« Reply #1 on: August 11, 2008, 10:58:24 AM »
Never had that myself so cant say a cure for it but maybe supplying 5v to the SS externally might help. You need to make sure you shift the on board jumper if you do it though.
