Hello Guest it is August 08, 2026, 05:38:22 AM
Author Topic: Offset whole layer  (Read 13316 times)
Offset whole layer
« on: August 10, 2008, 05:43:15 AM »
How to offset the whole LAYER?
When I select the layer, and do offset, it only applies to the last entity of the selected layer.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Offset whole layer
« Reply #1 on: August 10, 2008, 07:31:05 AM »
It may help to tell us what you are using and what layer you want to offset.
Graham.
« Reply #2 on: August 10, 2008, 03:00:55 PM »
Well, I try to offset layer with text, where every letter is an entity.
Basically, i export my design from CorelDraw in PLT, then load to Lazycam.
For example I would like to mill these letters, and to tell LAZYCAM to offset them 6mm (INSIDE - this is diameter of my flat mill).
thanks.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: August 11, 2008, 12:05:58 AM »
Hi, Skartalov
Post your PLT file, Use the REPLY Button and Attach It please.
It's late hear, I'll look at it tomorrow.
Thanks, Chip
« Reply #4 on: August 12, 2008, 12:42:39 AM »
OK, this is the file.
I would like to offset (Inside)  everything but the lines at once.
How to do that?
Offline Chip
  •  2,055 2,055
« Reply #5 on: August 12, 2008, 01:27:27 PM »
Hi, Skartalov
Loaded your file, Clean, Optimize, Set the short lines to a New layer "#2", Set Outer Box to New layer "#3".
Offset didn't work very well, So I set the text and short lines to .030 Depth and the box to .100.
You should be able to cut this with a engraving type tool, Pointy end cutter.
Hera's a G-code and .LCAM file to look at.
Hope this Helps, Chip
« Last Edit: August 12, 2008, 01:32:29 PM by Chip »
