Hello Guest it is June 03, 2026, 04:36:45 PM
Author Topic: Using a DRO in a Brain  (Read 26418 times)
« on: August 07, 2008, 06:01:01 PM »
I am trying to use a Y axis DRO to trigger clamps to release.  What I would like is to watch the DRO, and when it is between 10 and 20 inches from Z, to release an air cylinder (over ModIO).  I have control of the cylinder in a different brain.
I set up a brain that uses the Y axis DRO, then a >10, then a <20, then a NOP, then the modio address.  When I watch it and move the axis, the DRO value doesn't change.
Any thoughts?
Re: Using a DRO in a Brain
« Reply #1 on: August 07, 2008, 07:18:04 PM »
Yea, simple solution.
an example brain is attached.
but
YDro>compare(>10)
                               >AND these two drocompares>Output(x)
YDro>compare(<20)
See attached Brain,
Scott
« Reply #2 on: August 08, 2008, 08:51:13 AM »
Thanks Scott, I figured out that I need to enable the brain if I actually want it to work.
Roger
« Reply #3 on: April 26, 2014, 03:14:34 PM »
please how to write a macro and brain that will compare the current position of the x and y axes that use the bending machine with a default position that if the current position in the range of + - 50mm of default at the time when I have INPUT 1 one active program stops and activates OUTPUT 1
greeting
« Reply #4 on: June 02, 2014, 07:30:38 AM »
Post this to educate people who want to really study it.
