Greetings,
This plug in is a Smaller cousin to the Modbus one, It will allow Independant Jog speeds of up to all 6 axis, but you can use it on the Parrallel Ports!!!
You can use it for Independant Axis Jogspeed scaling from Emulated Keys, or real External Inputs through the PP.
It includes Example:
1). MachScreen: "1024IndependantJogPP.set"
2). XML: "IndependantJogPP"
3). Flash Help File that has a Walk through tutorial on setup and use, with pics.
Just down load the installer, and install.
The Installer called: "IndependantJogPP_vs_1.1.zip" is attached to this post.
NOTE: Fixed the installer, in where you can download and install it to any Directory that you have mach3 installed in, the Plugin Help files will now connect to that different location.
Scott
