Hello Guest it is November 12, 2026, 01:17:21 AM
Author Topic: Call for G-code display window  (Read 24996 times)
Offline Greolt
  •  956 956
« on: July 26, 2008, 06:31:45 AM »
Scott,  I am sure you will be able to help with this one.  ;D
Latest versions of Mach have a htm file with the Gcode explanations.  I find I look at it often.
This is the code behind the button,      HtmlDialog( GetMainFolder()+"Mach3MillGcode.htm" )
It opens in what looks like a restricted Internet Explorer window.  It is painfully small and not resizable.
My preferred browser is Firefox.  Is there a call that will open it in my choice of browser window?
Greg
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Call for G-code display window
« Reply #1 on: July 28, 2008, 12:12:34 PM »
Acualy you can have anything open up in anything by adding the path:
IE:
Code: [Select]
Shell "C:\Program Files\Internet Explorer\IEXPLORE.EXE "+ "C:\Mach3\Mach3MillGcode.htm", vbNormalFocus
FireFox:
Code: [Select]
Shell "C:\Program Files\Mozilla Firefox\firefox.exe "+ "C:\Mach3\Mach3MillGcode.htm", vbNormalFocus
!please take note to have a "Space after the location of the program you want to open the object with!
« Last Edit: July 28, 2008, 12:23:37 PM by zealous »
Offline Greolt
  •  956 956
« Reply #2 on: July 28, 2008, 04:54:26 PM »
Thanks for that Jason. Your the man!!!! ;D
That's just what I wanted.
While I am at it, can I change the "edit code" program from the Notepad default?
Greg
« Reply #3 on: July 28, 2008, 10:17:51 PM »
Greg
C'mon Greg, that's an easy one. General Config, top center, slightly to the left.  :)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #4 on: July 28, 2008, 10:19:45 PM »
Hey Greg,
Under "General Configuration" in Mach you can set the Gcode editor.
Or
If you need total control on what program to open the currentl loaded file in use something like this on the Edit button:
Code: [Select]
DoOEMbutton(168)'**Close the FIle first**
If(FileName="No File Loaded.")Then'**Check to see a file is loaded**
Print"LOAD A FILE FIRST"
Else
Shell "notepad "+ FileName, vbNormalFocus ' **YOU CAN DO THIS FOR NOTEPAD**
'Shell "C:\Program Files\Internet Explorer\IEXPLORE.EXE "+FileName, vbNormalFocus'**Or open in what you want**
End If
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: July 28, 2008, 10:21:06 PM »
Hey Gerry,
Thats funny we posted at the same time  ;D
Offline Greolt
  •  956 956
« Reply #6 on: July 28, 2008, 10:37:26 PM »
OK OK I feel suitably chastised........I thought I had seen it somewhere.  ;D
Jason,  thanks.
In this case I was not looking for that much control.  Just a better editor than Notepad.
Greg
