Hello
Guest
it is
April 25, 2024, 04:11:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
where is the motor reversal box
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: where is the motor reversal box (Read 3919 times)
timothysvec
6
on:
December 06, 2005, 01:57:20 PM »
Where is the motor reversal box located? Mach2 has it in configuration…….
I love mach2 but wanted to stay up to date and use mach3. do i have to switch the wires on my drives?
Cheers,
Tim svec
Logged
fer_mayrl
453
Re: where is the motor reversal box
Reply #1 on:
December 06, 2005, 02:06:11 PM »
They are in the config--> homing/limits, there is a column that says reversed, you can add a checkmark to the ones you want reversed.
Hope this helps
Fernando
Logged
Brian Barker
3,859
Reply #2 on:
December 06, 2005, 08:28:31 PM »
The other way to change this is under the ports and pins Active Low setting for the Dir pin on that axis...
Hope that helps
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
