Hello Guest it is June 08, 2026, 10:18:40 PM
Author Topic: How to use I/O from Galil 2143  (Read 8933 times)
« on: June 26, 2008, 02:26:48 AM »
Hi Friends
I am having Galil Controller 2143, I have downloaded Galil Plugin. Now i can run Motor using Mach3.
But i want to use I/O from Galil Controller.
Can anyone please advice how should i do it??
Manoj
Re: How to use I/O from Galil 2143
« Reply #1 on: June 26, 2008, 05:06:02 AM »
Yes,
  If memory serves, I think you can enable the I/O in ports and Pins, just like if it was a PP port. You match your 1st input from the Galil with the INPUT1 in ports and pins.
   I think someone posted up a Document, How to about this a while Back, I just cant find the doc/howto.
Perhaps someone like "Derek Ashburn" (aka "Hillbilly"), on the cnczone, and I forgot his user name here. He just put one on a machine not to long ago, that I helped him with a screen and Brains for it. I think he said, you have to look at your boards docs and enable this or that jumper or something, and then it comes into mach just like it was a PP port.
scott
