Hello Guest it is April 25, 2024, 04:01:02 AM
Author Topic: Routing Wood  (Read 78981 times)
  •  9,199 9,199
Re: Routing Wood
« Reply #40 on: June 21, 2008, 11:48:34 AM »
Nice work Budman68
I don't think my machine is up to cutting metal but I may give it a try. Did you use any coolant or just spray mist ?.
Re: Routing Wood
« Reply #41 on: June 21, 2008, 11:53:58 AM »
Thank you sir, actually neither, I use an air pump for an outdoor pond to keep the cutter/engraver cool and the chips clear so no chip welding occurs.
  •  9,199 9,199
Re: Routing Wood
« Reply #42 on: June 21, 2008, 12:04:57 PM »
Brilliant - I will now have to try and see if an air pump will work for cooling the cutter and plastic when I cut Lithophanes. If it does I can increase feedrates and reduce the machine time. I had never thought of using airflow but it seems obvious now you have said it.
I am learning lots from you guys, please keep it coming.
Offline docltf
  •  354 354
Re: Routing Wood
« Reply #43 on: June 22, 2008, 01:07:32 AM »
Tweakie,Budman,John S
Job well done guys.looking forward to seeing your upcoming projects.
bill
  •  9,199 9,199
Re: Routing Wood
« Reply #44 on: June 22, 2008, 11:42:18 AM »
Hi Bill,
Thanks for the compliments - now it's your turn to post a picture of what you have done.
  •  9,199 9,199
Re: Routing Wood
« Reply #45 on: June 23, 2008, 08:37:53 AM »
This was cut some time ago into a piece of scrap pine, it's a bit furry so the cutter was perhaps not so sharp.
I have been unable to locate the DXF or G-Code to make a better example to show you - so this will have to do !.
  •  9,199 9,199
Re: Routing Wood
« Reply #46 on: June 24, 2008, 10:17:52 AM »
Have you seen the wonderful wood routed panels on Flickr at http://www.flickr.com/photos/angelicdiablo/2601479294/ They apparently took 4.5 hours to route with a 0.125 inch ballnose using the ShopBot router.
Vector Art 3D have an evaluation version of their software at http://www.vectorart3d.com and a couple of sample files to cut.
I could not resist downloading their software and giving it a try this morning and here is my first attempt in MDF. Somehow VectorArt manage to remove the tool marks from their examples, perhaps I would get better results in hardwood as MDF is such awful stuff anyway. This example is approx 150 mm in diameter by 4 mm deep and took me approx. 45 minutes to complete.
« Last Edit: June 24, 2008, 12:03:16 PM by Tweakie.CNC »
  •  9,199 9,199
Re: Routing Wood
« Reply #47 on: June 26, 2008, 05:15:55 AM »
Another of the Vector Art 3D samples. This time smaller (10%) stepover and harder wood (ash, I think). Much better results but much longer cutting time.
Re: Routing Wood
« Reply #48 on: June 26, 2008, 12:05:07 PM »
absolutley beautiful, my friend-  :)
  •  9,199 9,199
Re: Routing Wood
« Reply #49 on: June 27, 2008, 02:33:48 AM »
This is a retry of a previous example - this time with a hardwood. Although a little sanding will be necessary the results are considerably better.
« Last Edit: June 27, 2008, 06:17:08 AM by Tweakie.CNC »
