Hello Guest it is April 18, 2024, 07:04:46 PM
Author Topic: Retrofit CNC Mill  (Read 8653 times)
Retrofit CNC Mill
« on: May 26, 2008, 12:18:24 PM »
I live in central Michigan and I am retrofitting a CNC  knee mill with Mach 3.  I am looking for somebody that could walk me through Mach 3 and hook up.  I am willing to pay for help within reason   Tony
Offline olf20
  •  325 325
Re: Retrofit CNC Mill
« Reply #1 on: May 27, 2008, 07:35:59 PM »
Hi Tony, I have converted a Atlas 10 x 54 knee mill. I done all the work myself (with a lot of help from the forum).
I will give you what I know, and I'm sure we can get you going.
Let me know what I can do!!
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #2 on: May 28, 2008, 06:38:59 PM »
Thanks for the reply
About parallel port has inputs  output and common how many do I need to drive one axis ?
Offline olf20
  •  325 325
« Reply #3 on: May 28, 2008, 07:31:07 PM »
Hi turboax, attached is a drawing that shows a typical layout. Now typical does not mean anything except some place
to start.
To drive one axis you need two outputs (1 step, and 1 direction). I'm assuming that you are using stepper motors.
With one break out board (BOB) you can have 5 inputs, and 12 outputs. A second parallel port can be added to most
computers to give you more inputs if needed. I have several other drawings that show differant aspects of the wiring.
Such things a limit switches, E stop, and so on.
Let me know what you need next, I'll be happy to help!!
olf20 / Bob
« Last Edit: May 28, 2008, 07:33:40 PM by olf20 »
« Reply #4 on: May 30, 2008, 05:44:07 PM »
 I am using DC servo motors how much of a difference is that?
Offline olf20
  •  325 325
« Reply #5 on: May 31, 2008, 07:35:52 AM »
Not much difference from a wiring point of view. I used steppers for costs reasons.
Here is another layout of a Servo System.
« Last Edit: May 31, 2008, 07:52:29 AM by olf20 »
« Reply #6 on: June 01, 2008, 09:02:31 PM »
how are  encoders  wired.  into  the PC or the servo's drives?
Offline olf20
  •  325 325
« Reply #7 on: June 01, 2008, 09:12:13 PM »
What motors are you using or plan on using??
olf20
« Reply #8 on: June 02, 2008, 07:12:55 PM »
It has DC Servo motors on it already.  Here's the thing.  The Servo drives are analog.  I am thinking that the best thing to do is switch drives and encoders.  I was looking over the drives on the machine and they are labeled 80 V and 15 amp.  Now I am looking at gecko drives 320 or 340 trying to decide on which one."   encoders are harder to shop for looking for recommendations.
« Last Edit: June 02, 2008, 07:45:40 PM by turboax »
Offline olf20
  •  325 325
« Reply #9 on: June 03, 2008, 07:26:04 AM »
Did you see this thread  http://www.machsupport.com/forum/index.php/topic,6853.0.html.
I'm not up on servo drives but Hood and others have lots of knowledge.
olf20
