Hello Guest it is June 08, 2026, 11:08:26 PM
Author Topic: Modbus setup screen is different than documented??  (Read 13740 times)
« on: May 23, 2008, 06:10:59 AM »
I am trying to configure Modbus to control my VFD. It appears that the Modbus screen has been changed since the documentation was done.
All I need to do is write to the first 4 coil registers on my VFD. I can control the VFD through the mod test screen without any problems. How do I translate the address and register locations used in the test screen to the modbus config screen?
I have tried executing a VB script I wrote and nothing is happening. Can you provide some suggestions?
Re: Modbus setup screen is different than documented??
« Reply #1 on: May 23, 2008, 11:28:46 AM »
I'm not sure if this is the issue but if you check the modbus plugin it changes that screen.
Just a sugestion
« Reply #2 on: May 24, 2008, 07:56:16 PM »
Ah, that got me back to the documented screen.
Following the steps in a different thread, I am now able to control my Hitachi VFD SJ200 over Modbus.
Thanks!
