Hello Guest it is April 24, 2024, 06:17:02 PM
Author Topic: Helical Gear cutting with Mach3  (Read 15010 times)
« on: March 31, 2008, 06:45:06 AM »
A sample of helical gear cut on PVC with Mach3:
Offline Glenn
  •  129 129
Re: Helical Gear cutting with Mach3
« Reply #1 on: March 31, 2008, 10:17:06 PM »
Hi jluisrey,
   Great gear!  How many axis does this process require,and
how deep of a cut can you take on each pass?
   Also..Do you write your own code or what program
do you use to generate it?
 Glenn ;)
Don't assume anything.....it'll make a Manager out of U and Me!
« Reply #2 on: April 01, 2008, 07:51:29 AM »
Hello Glenn,
3 Axis are used, X,Z,A, and the deep was 3mm, one pass cut (the material is PVC),
I write a small program and a excel sheet to generate gcode for gear, need tool angle, number of toochs, space bettwen tooch, and desired angle,
Rey
Benny
« Reply #3 on: April 03, 2008, 06:19:57 PM »
I would be interested to see the process of generating the gcode.
« Reply #4 on: April 04, 2008, 06:10:46 AM »
Hello,
Here you have the excell sheet and the program to generate the gcode, I will try to do a Mach3 wizard, but I don't know were to start ;O)
http://www.saand.es/joseyana/temp/gcode_helgears.zip
Regards
Rey
« Reply #5 on: April 05, 2008, 06:04:17 AM »
very cool
A axis?
and was wondering if you could paste the Gcode in a txt file
Thanks in advance :)
