Hello Guest it is November 30, 2026, 04:23:34 AM
Author Topic: Encoder_info_help  (Read 18285 times)
Offline Garyv
  •  103 103
Encoder_info_help
« on: March 07, 2008, 09:07:02 AM »
I_picked_up_a_few_servo_motors_on_ebay_last_week_and_need_an_encoder_it_had_a_tach_not_an_encoder_
and_the_other_one_is_a_Hirata_servo_with_a_DAITO_encoder_but_the_outputs_are_A-Signal_B-Signal-and_a_Z-signal_
Will_this_encoder_work_if_so_what_configuration_wouldI_use?
--I_am_running_gecko_320s_but_cant_get_this_encoder_to_work_
The_motor_starts_running_as_soon_as_I_engage_the_drivers_
The_motor_does_change_directions_and_slows_down_when_I_jog_but_seems_like_I_cant_get_the_encoder_to_work>
Also_where_can_I_get_a_few_regular_TTL_encoders>
I_have_not_seen_that_many_on_ebay_with_the_right_shaft_size_or_configuration?
Thanks_and_sorry_for_the_underlines_bad-keyboard_in_garage
GaryV
Re: Encoder_info_help
« Reply #1 on: March 07, 2008, 12:28:52 PM »
US Digital do reasonably priced encoders or look on eBay.
 Your Daito encoder  sounds like it should work but possibly the A and B are not TTL, maybe sine wave? What is the code number on the encoder?
Offline Garyv
  •  103 103
« Reply #2 on: March 07, 2008, 03:12:11 PM »
I_dont_think_it_is_TTL,Have_found_a_few_on_cheap_motors_on_ebay_today_they_are_on_the_way_but_the_model_of_the_encoder_is_DTRE-PWZK.
I_do_think_it_is_not_going_to_work_have-tried_all_combinations_and_nothing_..
GaryV
« Reply #3 on: March 07, 2008, 03:22:44 PM »
I looked earlier on Google for your encoders and came up a blank, obviously never had the code but still I couldnt find any info on any Daito encoders, so knowing the code probably wont change that.
 Do you have a scope? If you do then you could easily find out what the outputs of the encoder are.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: March 07, 2008, 03:35:59 PM »
Hi, GaryV
Colors of wires, terminal markings, picture of encoder, any aditional Info would Help.
Thanks, Chip
Offline Garyv
  •  103 103
« Reply #5 on: March 07, 2008, 03:40:50 PM »
No-scope_just-a_meter_only_open_wires_are_yellow_is_Z-sgn_blue_is_A_signal-and_green_is_B_signal_all-the-rest_are_tied_to_ground.
Oh_and-power_red_and_black--..
Offline Chip
  •  2,055 2,055
« Reply #6 on: March 07, 2008, 04:11:50 PM »
Hi, GaryV
You mat need pul-up resistors, Ref to Picture.
Thanks, Chip
Offline Garyv
  •  103 103
« Reply #7 on: March 07, 2008, 06:23:52 PM »
Chip-for_all_the_info..
I_am_going_to_try_that_while_waiting_for_the_new_encoders_to_come_it_it-might_work..
Always_trying-to_pick_up_a_few_tricks....
GaryV
