Hello Guest it is April 25, 2024, 06:00:31 PM
Author Topic: Video 180 Degree Rotation Needed  (Read 3995 times)
« on: January 16, 2008, 02:44:07 AM »
Hello,
I have mounted a 3Com Watchport/V camera on my Sherline 5410 CNC mill. Attachment was done effortlessly with Sherline's Z axis extension. The extension normally uses a 1/4-20 screw and I was able to use this to secure the camera looking down the Z axis.
Because the bottom of the camera is toward the rear of the machine the result is an inverted image.
The Mach3 Video Window plug in allows for the image to be flipped on the X axis to correct for a horizontal mirror image. In order to get my image displayed normally I also need the ability to flip on the Y axis. Both flips are equivalent to a 180 degree rotation which is what I need for the video image to appear normal.
Tom Hubin
thubin@earthlink.net
Re: Video 180 Degree Rotation Needed
« Reply #1 on: April 06, 2008, 04:18:50 AM »
Did you find out how to flip on X axis ?
I have also some issues on mouse moving on Y axis- it is moving in the opposite direction that it should.
Daniel
« Reply #2 on: April 08, 2008, 06:22:20 PM »
Hello Daniel,
No.
I think very few people are experimenting with laser triangulation so it has not yet become an issue.
Tom Hubin
