Hello Guest it is March 29, 2024, 08:22:06 AM
Author Topic: anilam 1100 retrofit  (Read 4916 times)
Offline comet
  •  336 336
« on: January 12, 2008, 02:47:36 PM »
Guys,
  just bought a large turretmill (5hp) that is equiped with an anilam 1100m controll
and servo,s. its a 1996 machine.
  althought the anilam works perfectly and the drives are good ect, I am used to using mach3
so I would like to link mach3 to the drives and remove the anilam controll do I need those pixies?
  Any advice positive or negative would be appreciated.
      Tony
Re: anilam 1100 retrofit
« Reply #1 on: January 12, 2008, 03:39:42 PM »
Probably, only problem is I think pixies are no longer made :(
 There is a slim chance that your drives can take step/dir, do you know the type and model of them?
« Reply #2 on: January 12, 2008, 03:46:01 PM »
BTW Rutex do a Ste/Dir to Analogue converter, no experience of it but it might be worth a look if your drives are not capable of Step/Dir.
 The Rutex number is R991H
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: January 12, 2008, 03:49:39 PM »
Hi, Tony
Converted a Anilam 1000 awhile back, Used Gecko's, New transformer down to 80 volts, With the encoders feedback on the Table it's a little nervous, But works well. Lost a little top speed with the 100 v to 80 v though
Pixies may be hard to get now, Have used Rutex in the past, may be hard to get also, There other +- 10 volt boards out there, Hopefully others will comment on them.
Hope this Helps, Chip
