Hi, Spinnetti
1. How do I order the chains?, I found how to select them individually, but not which direction or in which order. This is important because I have to cut a particular order out of the stock
Click on the first chain you want it will turn gray on the left side, Click on it on the left, Hold left mouse key down and drag it on top of chain0.
Chain0 will move down one, repeat this till you have the order you want.
2. There is no stock definition? - would be nice to see what I'm cutting out of.
Best you can do is, Draw it in your DXF, Then delete it before posting.
3. There is no path simulation of the cut? - that would be nice too
Hit the "S" key to turn on the Rat, Hit the "S" key again to turn it off.
Hope this Helps, Chip
