Hello Guest it is April 19, 2024, 02:13:06 AM
Author Topic: CorelDraw engrave  (Read 59193 times)
Re: CorelDraw engrave
« Reply #20 on: August 09, 2011, 01:17:16 AM »
Hi
I have made a new version for this screen with some new functions and bug fixes.
( version 0.98 )
Its not possible to modify my first post in this topic to upload the file for download. :'(
Is this function disabled? Can someone help me with this?
Gretings
roger
« Reply #21 on: August 25, 2011, 10:31:02 AM »
Hi Roger,
Great and professional work.
Plt is the most popular file used in engraving machines, and corel is very good in hpgl files.
I have a small suggestion ,if you can add (start position ) =(top left) or (center) or (bottom left).
Thank you for your efforts.
Usama
« Reply #22 on: August 25, 2011, 12:34:14 PM »
( version 0.98 )
I am looking forward to seeing your new revision. Hopefully a Moderator can help you update your original post; or you can just upload it and all will understand.
« Reply #23 on: August 25, 2011, 02:29:36 PM »
Hi
( version 0.98 )
Gretings
roger
Roger,
I contacted those who know how to do this for you, so hopefully you'll here something fairly soon.
« Reply #24 on: August 26, 2011, 05:28:23 AM »
Good suggestion Usama!
I can make a home position for the tool ( drill ) to start from, and returning to this position after the job is done.
Just give me a few days to look into this.
Greetings
Roger
andrewm
« Reply #25 on: August 26, 2011, 11:40:08 AM »
Hi Roger
I took off the old file, you can post it in a new topic now or send it to me via email and I will add it onto your first post.
andrewm
« Reply #26 on: August 29, 2011, 09:23:08 AM »
Hi Roger
You Should be all set now
« Reply #27 on: October 25, 2011, 10:50:28 AM »
How do you get the feedrate and other options when your exporting from Corel?  All I get is Pen, Color, Width, & Velocity.  Do I have to drop something in the Corel plug-in folder or something?
« Reply #28 on: October 25, 2011, 11:20:54 AM »
Hi
You can ignore the PEN settings in the hpgl export from corel.
All settings can be changed in mach3 screen.
Some values you enter cant be zero or positive numbers.
In the errormessage you can see the
Greater than sine >
Or Less than sine <
Adjust the value and it will be ok.
See attachment with my hpgl export settings
Hope it works
« Reply #29 on: December 01, 2012, 01:31:23 PM »
Is this an add-on for mach3 or coreldraw?  I have X5 and would like to use this.  I am new to mach3.  How can I get it?
Thanks!
