Hello Guest it is November 20, 2026, 05:12:59 PM
Author Topic: G54-G59 Work offsets  (Read 97059 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G54-G59 Work offsets
« Reply #10 on: December 14, 2007, 05:12:35 AM »
That about sums it up.
G54 is set every time the fixture is set up because the fixture may be in a different place on the machine.
G52's are hard coded into the program as the parts on the fixture should/will be in the same place every time relative to the G54.
Graham.
Offline TT350
  •  113 113
« Reply #11 on: December 14, 2007, 06:59:51 AM »
Thanks again Graham.
I'm going to play with it this weekend
wish me luck.
Chirs
« Reply #12 on: May 09, 2008, 04:40:59 PM »
Dear,
I have made 2 part-program with G54, G55 e G56 function e another with G52.
The toolpath it´s incorrect. See de part-program in anexx.
  •  2,785 2,785
« Reply #13 on: May 10, 2008, 06:20:05 AM »
Hi M.Jonas,
the code you have written will produce 3 100mm squares at 3 different points, the points are set in the work offset table.
If the squares are in the wrong places then the work offsets are set wrong.
More information will help to solve your problem.
Graham.
« Reply #14 on: November 24, 2009, 06:31:38 PM »
How can I store the data for coordinate offset G54-59 in Mach3 ? I have to enter these data every time turn on the Mach 3 program. The tool offset page has the button to save the data but it does not work. Once I exit the mach 3 program it is gone.
Thanks for the help
peter
  •  2,785 2,785
« Reply #15 on: November 24, 2009, 06:42:53 PM »
On the offsets page click 'Save work offsets', then click 'Save' in the window that pops up.
If that dose not work, go to Config menu, select Fixtures..., click save.
Graham
« Reply #16 on: November 25, 2009, 09:31:21 PM »
Graham, It still does not work. I click the "save" button in the save work offset window, nothing happen. I have to click "close" to exit this window. In the Config, fixture, it will pup up the same window, off course  the "save" button is not work either. Once I exit the mach3, the data is gone. Is there anything missing in the mach3 set up ?
Thanks for your help.
« Reply #17 on: November 26, 2009, 10:01:28 AM »
Graham,
Never mind. I just found out that the G54 is the default value which can not be saved but G55 to G59 is working.
  •  2,785 2,785
« Reply #18 on: November 26, 2009, 03:56:26 PM »
What do you have set in general config, is it like this :-
« Reply #19 on: November 26, 2009, 05:01:04 PM »
OK, It was not and I change to this setting then the G54 "save" is working.
Thanks, Happy Thanks Givening
