oh no!
over 120 days since the last post!
forgive me... im sure that happens a lot on this site... you get crucified on other sites for it... oh well... resurrection!
so, ive had a gander through a few pages and didnt see my specific requirements listed, and looking at the screenshot... it doesnt have it.
i am winding induction coils AND output transformers. and a few other things here and there.
both require a pause in between each layer, then maybe a slow turn as i have to wrap insulation on each time.
and, as each layer has a slight overlap... i need the ends of each layer to stagger slightly, otherwise i wind up (oh ha-de-ha!) with a rather awkward bulge. for the induction coil it isnt that big a deal (as long as i make the box AFTER ive done!) but with the OPT it can be a struggle when you have to get that window as full as possible and theres a double layer of insulation right where its not wanted... not nice, damaging $80 worth of copper cus you tried squashing the coil in the vice... (actually, my stuff up was not realising the final core lamination sliced into the bobbin and cut through one strand...
at least the second time i wound it it looked damn professional! only lost an inch of wire. very. last. turn. or first, i guess, from a winding perspective...)
yes, ok, just orient the bobbin so the overlap sticks out to the front (or back)... that works for the OPT i guess.
so far ive just been running under a lathe profile, simple winder from the bits and pieces off my old 3d printer, and a nested subroutine using M1 stops each layer. works... sort of ok.
spindle is A axis, stepper motor, so i can keep it synched up without any encoders.. i am noticing though, that it almost stops on each turn. just running incremental, X back and forth at the wire diameter, with A constantly incrementing 360. easy... but not perfect. CV mode. i suppose i can always go absolute and do the maths... 500 turns of 0.125 is 75mm at 180,001 (stagger!) degrees for example...
yet it seemed to not do that the other day... and only does it when i start pushing the feed rate over 130%... (feeding at 10,000 degrees/min... pretty slow)
lets just say its awkward when i snap the wire... which happens fairly often with the current coil, as im re-using the old silk wound and rosin impregnated wire from the induction coil (some old pre-1900's thing... i got carried away replacing its lead out wires...) have to unwind the last layer, reset it all... homing switches? whats a homing switch? i whipped this winder up in about 2 hours... dead basic. it also means i have to keep track of the layers ive completed, because a snapped wire invariably means i have to run the code again. i guess i could just un-nest that subroutine, seeing as i have to hit run on every layer anyway... but still have to keep track.
soooo... i have no idea how to modify this... what is it? VB code?
i dont really want to spend the next few days learning how to do so...
iunno. it just seems like it would be the final addition that would make this screenset super user-friendly! a pause for layers, and a few degrees of stagger on each layer. just a wee little extra option... hint hint!
anyway, only got 28 layers left. this ones easy. just frustrating. im procrastinating... yes, i just snapped the wire again!
i am dreading my next project though... 50,000 turns of 0.1mm... twice. yep. 100,000 turns in total, in 100 layers, on two bobbins... im aiming for about 500KV... gunna make one HELL of a jacobs ladder! (yes, i know how to deal with high voltages, dont worry... otherwise i wouldnt be here still!) local scrapyard has spools ranging from 4 to 20kg... $10 a kg. shame the sizes are mostly useless for just about anything but guitar pickups...
and yeah, i gotta do the other OPT on the stereo... i did set up a manual winder with printed gears and the leadscrew from the mill from when i converted it to CNC. two years ago. ive forgotten exactly what i did... and it was all held together with g-clamps anyway... i needed them!
yeah yeah, long winded post...
right. coffees drunk, ciggies smoked, post is completed... back to winding!
