Hello Guest it is April 23, 2024, 07:31:51 AM
Author Topic: Coil winding machine ( Wizard needed)  (Read 267183 times)
Re: Coil winding machine ( Wizard needed)
« Reply #80 on: May 31, 2018, 02:48:51 PM »
Hi Craig,
I have already did that, but nothing is change.
Faith.
« Reply #81 on: May 31, 2018, 03:01:26 PM »
Hi.
so what actually happens?
Does Mach3 attempt to load and run?
I'm begining to think you may have a corrupt copy of Mach. May I suggest delete the C:\Mach3 folder and download a fresh copy.
This time when you are asked to select a profile at start up select the standard mill profile. Start from there.
« Reply #82 on: May 31, 2018, 03:12:52 PM »
Hi.
Ok Craig, i will do and i'll send the results.
Thanks again :)
« Reply #83 on: May 31, 2018, 03:34:23 PM »
Actually, nothing is changed.
screenshot: https://ibb.co/czZ8oJ
« Reply #84 on: May 31, 2018, 04:54:53 PM »
did you attempt to run one of the standard screen sets and standard mill profile as  I suggested?.
That coil winding screen is as old as the hills and was never completed. I'm not sure how much
use you'd get from it.
I use Mach4 and wrote my own coil winding script.
You might try to download Mach4 just to see whether it will install and run on your PC.
« Reply #85 on: May 31, 2018, 05:11:56 PM »
you may have noted that some of the latest updates from Microsoft, particularly Windows 10,
have interfered with Mach3. I wonder if that is what is happening to you.
http://www.machsupport.com/forum/index.php/topic,37291.0.html
  •  9,199 9,199
« Reply #86 on: June 01, 2018, 01:42:43 AM »
Hi carman,
You are missing the graphics so you need to copy the Coil winder bitmaps folder to the Mach3 Bitmaps folder.
« Reply #87 on: June 01, 2018, 08:37:40 AM »
Hi Craig,
I did exactly what you said.
Hi Tweakie,
Unfortunately, there is no bitmap folder (inside attachment/zip files).
Faith.
  •  9,199 9,199
« Reply #88 on: June 01, 2018, 10:30:35 AM »
Hi Craig,
Hi Tweakie,
Faith.
The downloaded folder 'Coil winder' should be added to your Mach3 bitmaps folder.
« Last Edit: June 01, 2018, 10:34:28 AM by Tweakie.CNC »
« Reply #89 on: June 02, 2018, 07:49:49 AM »
I will check in monday.
Thanks Tweakie.
