Welcome, Guest. Please login or register.
Did you miss your activation email?
September 02, 2010, 07:11:28 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Newfangled Solutions Wizards (Moderator: Ron Ginger)
| | |-+  Coil winding machine ( Wizard needed)
Pages: « 1 2 3 4 5 6 7 8 »   Go Down
Print
Author Topic: Coil winding machine ( Wizard needed)  (Read 34417 times)
pavel59
Holding
Offline Offline
View Profile
« Reply #10 on: February 04, 2006, 06:03:05 PM »
Hi to all, this project sounds quite interesting to me, but I would also get your opinion about the feasibility of a similar machine to be used for winding wet reinforcing fibers (technical name of technology is "filament winding") around a mandrel.
The main difference between the coil winding and the filament winding is that the fibers should follow an angled pattern (crossing at certain degrees) instead of being parallel to each other.
Paolo
Logged
Whirlybird
Active Member
Offline Offline
View Profile
« Reply #11 on: April 12, 2006, 08:17:19 PM »
Hi all you coil winders out there
Ihope this project does not stall before it gets off the ground.
Wishing to automate the winding of coils for special alternators for use in small scale wind turbines.
In these coils it is important to keep the actual thickness of the coil to a minimum and to acheive this the change of direction has to be acurate so as not to have uneven layers.
Logged
Strat
Active Member
Offline Offline
View Profile
« Reply #12 on: April 13, 2006, 08:52:27 PM »
as far as the winder mine is built just a matter of swapping steppers over but had to keep the standard motors on for now  to much to do and never enough time Roll Eyes  anyways lookin forward to this
Logged
ballendo
Active Member
Offline Offline
View Profile
« Reply #13 on: April 15, 2006, 12:58:53 AM »
Benny,
I know you've detailed this before, and forvgive me for asking here if this is not the place...
What software tools are you using to create the screens you post?
What specific software was used to create this coil winder screen?
Thank you in advance,
Ballendo
So far the only variables I can think of are as attached.
Can anyone think of any others.
We could use a single BMP with invisible buttons and inputs. This would make it easy to do.
Logged
patanke
Active Member
Offline Offline
View Profile
« Reply #14 on: May 08, 2006, 10:30:09 PM »
Ok I'll bite, I got a machine built and will have it next week at the cnc-workshop. I just sent the funds to buy the program today.  I'll post pictures of the machine tomorrow.  It uses 2 sure step steppers and a chunk of hsk rail and ballscrew I had lying arround.
I'm one of those guys that is better at hardware than software, so I realy apreshiate your offer for the coding. What format would you like the screen graphics in? Brian will you be at the workshop?
Logged
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #15 on: May 09, 2006, 05:44:59 AM »
Sounds good to me we can code it up at te workshop Smiley Benny could you please send me the screen set?
Logged
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
ynneb
Guest
« Reply #16 on: May 09, 2006, 08:32:10 AM »
Brian, everything is placed on the set, and I have set every thing that I know how to do. The rest is up to you Smiley
I have deliberatly left the slider in there even though its a no goer, in the hope that lots of people will make posts saying that it does not work, and Art will get the hint that he should initiate it Smiley
If you get it going at the show, I want someone to make a video of it winding. Please Smiley
In fact I want lost of video footage of all the activity there. I will then make a download section dedicated to the show.
* coil winder.zip (156 KB - downloaded 471 times.)
« Last Edit: May 09, 2006, 08:39:01 AM by ynneb » Logged
patanke
Active Member
Offline Offline
View Profile
« Reply #17 on: May 10, 2006, 09:07:21 AM »
here are the pics I promised
Logged
ynneb
Guest
« Reply #18 on: May 10, 2006, 06:55:25 PM »
Supurb job, Patanke. This will be a show stopper at the conference.
This is eactly how I was hoping this project to progress. A good team effort happening here.
Dont forget to make a tensioning system too. Probably two bits of thick felt mounted in an adjustable clamp would do the trick.
Gee I wish I could come to the show and see it.
« Last Edit: May 10, 2006, 07:28:49 PM by ynneb » Logged
Whirlybird
Active Member
Offline Offline
View Profile
« Reply #19 on: May 10, 2006, 10:11:31 PM »
wow
Thats as nice a bit of engineering as i have seen in a while Good work
could you imagine something like that but with a six meter long bed on it.
Because I can
Logged
Pages: « 1 2 3 4 5 6 7 8 »   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
