Hello Guest it is April 18, 2024, 12:10:33 PM
Author Topic: Gear Cutting with 4th Axis  (Read 12070 times)
Offline Al
  •  12 12
« on: November 26, 2007, 03:22:58 AM »
My apologies to all if this is a duplicate, but I have been looking for the past 2 hrs and cannot find anything on th NFS Wizard Gear cutting and using a 4th axis.
Am I missing the info some where? or is the gear wizard only for a manual rotary table?
Thanks all
Al
Do it today! Tomorrow is Unknown
vmax549
Re: Gear Cutting with 4th Axis
« Reply #1 on: January 25, 2008, 11:31:07 AM »
Good Morning AL, what do you need to know??
« Reply #2 on: January 25, 2008, 07:33:18 PM »
The wizard does use the A axis. It generates a subroutine that makes the A move, so the code looks a bit strange if oyu are not used to subroutines.
« Reply #3 on: November 14, 2016, 06:33:17 PM »
I must be a moron but in the gear cutting wizard, which number do you use to cut blank from the right (behind).
What settings would you use to cut 1 inch blank with 30 gears. Going right to left from the back.
