Hello
Guest
it is
April 24, 2024, 09:21:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MDI Screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MDI Screen (Read 5249 times)
Rkjohn
65
MDI Screen
on:
October 07, 2007, 07:51:39 PM »
Sometimes the MDI screen works for inputs & sometimes it doesnt. How do you activate it? Also I'm showing +90.0000 but I only have 30" axis. How do I set this so it will show actual inches traveled?
Logged
Chaoticone
5,624
Precision Chaos
Re: MDI Screen
Reply #1 on:
October 07, 2007, 09:21:37 PM »
What inputs? Can you give more detail? If it is the spindle, is it the dwell that makes it seem like it's not working?
Logged
If you could see the things I have in my head, you would be laughing too.
Rkjohn
65
Re: MDI Screen
Reply #2 on:
October 07, 2007, 10:01:53 PM »
When I go to the MDI sceen & input X6 it does nothing, X does not move, I tried with jog on & off.
How do I get scale to inchs for machine coord's.
Logged
Chaoticone
5,624
Precision Chaos
Re: MDI Screen
Reply #3 on:
October 07, 2007, 10:09:26 PM »
You have to give it a G command. G0 for rapid or G1 for a feed. Feed moves also need an f value.
Try this,
G0 X6
G1 X0 F15
Logged
Chaoticone
5,624
Precision Chaos
Re: MDI Screen
Reply #4 on:
October 07, 2007, 10:12:08 PM »
Oh yeah, look on the settings page to change from inches to mm. Can also be done with g code, and config, deafault units.
Logged
Rkjohn
65
Re: MDI Screen
Reply #5 on:
October 07, 2007, 10:17:49 PM »
Im set to inches & have entered code G20. Should I go to "General Logic" & "Lock DRO's to setup?
Logged
Chaoticone
5,624
Precision Chaos
Re: MDI Screen
Reply #6 on:
October 07, 2007, 10:19:19 PM »
Lock DRO's locks them to your setup units.
Logged
Rkjohn
65
Re: MDI Screen
Reply #7 on:
October 07, 2007, 10:21:00 PM »
G1 X0 F15 works.
Logged
Rkjohn
65
Re: MDI Screen
Reply #8 on:
October 07, 2007, 10:57:53 PM »
Heres the problem. Just went to the machine,,,,, when I put in X1 - Y1 - Z1... I thought it would move 1", but it only moves 1/8". Have a suggestion?
Logged
Chaoticone
5,624
Precision Chaos
Re: MDI Screen
Reply #9 on:
October 07, 2007, 11:08:44 PM »
I have sent you a personal message.
Logged
Print
Pages:
1
Go Up
« previous
next »
