Hello Guest it is April 19, 2024, 02:44:03 PM
Author Topic: Constant velocity  (Read 46288 times)
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
Re: Constant velocity
« Reply #40 on: October 23, 2007, 10:04:39 AM »
Hi Guys:
  If you redownload 2.56 , youll find it reports at 2.56.1 , and the fix is in that file. Let me know if you see a CV problem in your files on this version, we think weve caught it, the spline file seems to run OK, but you never know, it can take a coupel of iterations to get it right sometimes..
Art
vmax549
« Reply #41 on: October 23, 2007, 12:57:58 PM »
Hi Art ,I just redownloaded V2.56 and it still reports as 2.56 not 2.56.1??
(;-) Tp
« Reply #42 on: October 23, 2007, 05:44:23 PM »
Art,
Installed 2.56.1 and ran my old jobs, they all ran OK.  Generated a wild test program for CV and it also worked fine.
As far as I'm concerned everything is working correctly again.
Tom
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #43 on: October 24, 2007, 04:58:35 AM »
tried to break it - but it just wouldn't - nice job. Thanks to all involved.
TP, mine also reports 2.56 but I noticed during install that it said it was upgrading to 2.56.1
Ian
« Last Edit: October 24, 2007, 05:03:51 AM by stirling »
« Reply #44 on: October 24, 2007, 09:54:07 AM »
Hello all,
when you do an update of MACH3, how do you make it? Just starting the installer-exe or cleaning the Mach3-folder before or is there an un-install tool anywhere?
I'm just in the test phase with Mach software, therefore not yet too familiar with it.
Thanks for advise.
Regards
Holger
« Reply #45 on: October 24, 2007, 10:13:35 AM »
You just download and install. It will ask if you want to write over the older version, just click yes. I would save a copy of my xml files, screensets, adn grabber profiles to an external disk before I installed the new. You should be ok without the back up, better safe than sorry.
Offline Repmo
  •  54 54
« Reply #46 on: October 28, 2007, 08:52:02 AM »
try to disable backlash
