Hello Guest it is July 10, 2026, 09:46:58 PM
Author Topic: Font gngrave wizard  (Read 12306 times)
0 Members and 4 Guests are viewing this topic.
Font gngrave wizard
« on: November 07, 2018, 09:06:13 AM »
Has anyone used the font engrave wizard in mach 4?
 I need to know how to set font / type spaceing to engrave properly. Any help would be great.
Ken
Re: Topic moved
« Reply #1 on: November 07, 2018, 09:48:34 AM »
My topic has been moved to tweakie!
What does that mean????
Ken
Re: Font gngrave wizard
« Reply #2 on: November 07, 2018, 12:47:58 PM »
So i signed up for a tweakie account, am i understanding that i shouldn't use mach support anymore??
Ken
Offline ZASto
  •  434 434
« Reply #3 on: November 07, 2018, 04:41:31 PM »
No, your topic was moved to appropriate area: Mach4 General Discussion.
The area: MachGeneral Discussion is mainly for Mach3, when Mach 4 was not even in diapers :) (look at the dates of first posts in these areas).
Anyway you are welcome to the forum.
My personality is who I am.
  •  9,362 9,362
« Reply #4 on: November 08, 2018, 12:46:08 AM »
Hi Ken,
My apologies if I caused any distress by moving your original posting from the General to the Mach4 sections of the forum. This was done to enable your posting to get the maximum coverage and the fastest response from those who are expert at using Mach4.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #5 on: November 08, 2018, 06:02:39 AM »
There is a video on the MachSupport Youtube channel https://www.youtube.com/watch?v=vvjLEMvBRYQ
DazTheGas
« Reply #6 on: November 08, 2018, 06:25:32 AM »
Thanks for the clairifacation. I hope i am in trhe right spot now. When you get to my age you always hope your in the right place.
Thanks again
Ken
« Reply #7 on: November 08, 2018, 06:44:54 AM »
I watched the utube link and i have watched it several times previously to see if i was missing something. The issue i have is the auto calculator for font size always sets the font just overlaping each letter slightly no matter how big or small i set it.
I am using the straight line font provided
How can change this letter spacing?
Ken
Offline Stuart
  •  311 311
« Reply #8 on: November 08, 2018, 08:55:35 AM »
Ken
A quick question
Have you actually cut the result of the wizard into actual material or are you just looking at the simulation/or wizard screen output
It could be if it’s the screen you are seeing this is a graphic problem rather than a cutting problem
If you have cut this output and it’s wrong then disregard my comments
Stuart
« Reply #9 on: November 08, 2018, 11:11:08 AM »
Hello Stuart,
The screen display looks fine, its the actual cut that laps, touches etc, they cut into the edge of the previous letter. There must be something i am not doing or doing wrong!!!
Ken
