Hello Guest it is March 28, 2024, 04:50:02 AM
Author Topic: Issues getting Stepper Motors to move with Pokeys57CNC  (Read 2358 times)
« on: October 17, 2018, 03:23:11 PM »
Okay...I am not a newbie to CNC machines, but I am new to PoKeys and Mach4. I also opted to buy Polabs stepper drivers because they were Ic2 capable. Here is my configuration followed by my issue.
Controller: Pokeys57CNC
Stepper Driver: Postep60-256
Software: Mach4 (V4.2.0.3804) Pokey Plugin (V8.49.0.3813)
Power Supply: 24v (Controller Board) 36v (Stepper Drivers)
Spindle: 1.5Kw (Hyoung 120v Inverter)
Stepper Motors:
    X-Axis: Nema 24 / 425oz
    Y-Axis: Nema 24 / 425oz
    Z-Axis: Nema 24 / 425oz
Home / Axis- Switch:
    X-Axis: NO Mechanical
    Y-Axis: NO Mechanical
    Z-Axis: NO Mechanical
Limit / Axis+ Switch:
    X-Axis: None
    Y-Axis: None
    Z-Axis: None
What I have done so far...
On my first run I used Pokeys configuration and used the limit switch wizard to set the inputs; closed Mach4.
I opened each Postep60 driver with the software and set-up the driver, and ran them via the software, so I know that they are wired properly.
I restarted Mach4 and opened Pokeys plugin and inverted E-stop in Pokeys Plugin.
All seems well when I jog the axis (DRO moves), but the motors will not move. There are no warnings or limits activated.
Any ideas where I go from here?
Re: Issues getting Stepper Motors to move with Pokeys57CNC
« Reply #1 on: October 18, 2018, 01:00:25 PM »
I got it fixed...this forum is great didn't even need a reply to get the answer.
Just in case you are having the same problem...
1. Check ribbon connectors
2. Try to invert the enable output in Mach4
« Reply #2 on: October 20, 2018, 07:00:12 AM »
Thanks for posting your fix. It will help somebody in the future.
Mike
