Hello Guest it is April 23, 2024, 09:15:35 PM
Author Topic: XHC MK4 mach4 motherboard last drivers  (Read 2426 times)
« on: October 11, 2018, 08:47:41 AM »
After a long time with the engineer to find a solution to the problem, he sended to me an updated drivers that, now, control the spindle speed by the gcode command and the slider into the software
I hope it will help some users !
  •  9,199 9,199
Re: XHC MK4 mach4 motherboard last drivers
« Reply #1 on: October 11, 2018, 10:29:27 AM »
Hi mcbride19,
Thank you for sharing this information and the updated plugin.
« Reply #2 on: October 11, 2018, 12:52:32 PM »
Knowledge is powerful only when it's shared ;)
« Reply #3 on: October 18, 2018, 08:49:24 PM »
Hi
I have ordered a XHC controller and are just getting every thing ready thanks for yous post  "I have down loaded the file
Can I ask is your machine running ok and working good ?   what computer operating system are you using my controller is a USB connection and I am thinking of buying a new computer which will come with windows 10 do you know if that will work ok
Thanks Ray
« Reply #4 on: October 19, 2018, 12:45:05 AM »
Yes my CNC is working good it's a 3040 with 800w spindle(watercooled) with 4 axis.
I have the XHC Mk4 mach4 USB motherboard.
here is my CNC:
I'm working on windows 10 and windows 8.
Except the fact that it came with a "hacked" version of Mach3 I will say that it's a good product.
For a new computer to pilot your cnc you don't need to buy a big one(I mean 8 cores with 32 Go memory etc ...), a simple one is able to pilot the CNC, but you will need a power one to calculate the Gcode if you are doing complex milling(with a lot of path) or else the calculating time will be longer (of course).
