Hello Guest it is April 25, 2024, 04:14:06 PM
Author Topic: HiCon Plug Crash  (Read 2474 times)
Offline Boots
  •  17 17
HiCon Plug Crash
« on: October 06, 2018, 05:53:53 PM »
Install Hicon Intergra 7766 with 7377 Hicon plugin crash
System: Dell Precision, Windows 7, 7766, 7377 boards, Mach4 install
When I try to configure HiCon Device (Config>Select Motion Device) it comes up with an error: Config Data not Initialized or Corrupt. Then in goes to the Dos screen and says "Configuration Download Success" Then it closes Mach4.
When I Re-start Mach4 and run VSI Device Manager and then San the Network is shows the correct IP connection. HiCon is also shown in the window below. I also enabled "J7 step and Direction" and clicked Download. But it still crashes.  ???
?? Could uses some help, Boots-2b1
