Hello Guest it is March 29, 2024, 11:40:12 AM
Author Topic: I just want to start machining, darn-it!  (Read 1319 times)
« on: October 04, 2018, 01:26:19 PM »
What desktop CNC (similar to a 3040 series) is out there that works with Mach3 in the $800 price range. I ran aground trying to set up a chinese CNC 3040 series with a mini blue box controller with horrible instructions - just can't get it to work.
Mach3 software is working well, driver test successful... I just want to start machining, darn-it!
Thanks for anyone's help.
Offline ZASto
  •  423 423
Re: I just want to start machining, darn-it!
« Reply #1 on: October 04, 2018, 02:06:29 PM »
Ask seller to help you.
You know, this is hot a chineese machine support forum.
And, BTW, you have to learn chinglish :)
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #2 on: October 04, 2018, 02:07:37 PM »
You don’t say what interface it uses. If it is parallel you’ll be limited to a PC with a parallel port and an older version of Windows. If it has USB it should have come with a driver on a CD, and should work with newer versions of Windows.
« Reply #3 on: October 04, 2018, 04:50:46 PM »
I have a parallel port on Windows 7 professional 32bit. The chinglish installation CD has three steps which I have followed for a couple of weeks now.
I'm open for recommendations from fellow forum participants that have recently purchased their cnc 3040 and were able to get going with minimal software/hardware interface.
« Reply #4 on: October 04, 2018, 07:42:22 PM »
You need to provide a lot of detail of what is not working.
Are the motors locked up?
If so, then most likely either the port address is wrong, or the port and/or pin numbers are wrong.
