Hello Guest it is April 26, 2024, 12:21:39 AM
Author Topic: Controller and drivers  (Read 15197 times)
Re: Controller and drivers
« Reply #20 on: October 08, 2018, 05:31:23 PM »
Hey Craig,
Are these the correct models:
Driver: DYN4-L01A2-00 0.05 ~ 0.4kW                                        $218.00
Motor: 640-DST-A6HS1 0.40kW     1.27N.m  3.82N.m  60mm        $177.00
Model numbers found here, under System Selection: http://www.dmm-tech.com/Dyn4_main.html
TJoensen
« Reply #21 on: October 08, 2018, 11:43:23 PM »
yes they'll do the job nicely. Considerably cheaper than the Schnieder ones you linked to earlier.
You may have noted there are a couple of choices. You could use 60V units which are a little cheaper,
you would of course require a separate 60V power supply, rather denting any cost saving.
The DYN4 models are 220VAC input, yep just hook them up to the incoming mains voltage via a fuse/breaker/contactor
or whatever.....no extra power supply required. These would be preferred. Naturally if you choose the 200V drives
then you'll want the 200V servos as you have listed.
I note in one of my earlier posts I claimed the price was $147....but that was for the 60V unit.....good spotting
on your part, it so easy to make a mistake.
« Reply #22 on: October 09, 2018, 06:47:47 AM »
Is the BoB used to connect emergency stop and other buttons?
Do cables and other accessories come with the products, or are purchased separately ?
TJoensen
« Reply #23 on: October 09, 2018, 07:06:40 AM »
Cables and all accessories are extra.
When you buy a drive, all you get is the drive.
When you buy a motor, you just get the motor.
The DMM breakout board has a limited number of inputs (4?) one for E-Stop, and 3 for limit switches, but you could use them for buttons or other things.
There are many other breakout boards available. You don't have to use DMM's bob.
« Reply #24 on: October 09, 2018, 07:50:48 AM »
What BoB would you recommend to go with the ESS ?
TJoensen
« Reply #25 on: October 09, 2018, 08:01:49 AM »
MB2 from CNC Room, as I mentioned earlier. But it may be a lot more than you need.
« Reply #26 on: October 09, 2018, 11:13:36 AM »
Is it possible to use Mach 4 with the ESS on a laptop? Or do I need a desktop ?
TJoensen
« Reply #27 on: October 09, 2018, 11:32:09 AM »
ger21,
How's the MB2-02-V6 from Homann Designs ?
The MB2 from CNC Room is abit expensive.
TJoensen
« Reply #28 on: October 09, 2018, 12:08:40 PM »
I don't have any experience with it, but Peter Homann has an excellent reputation in the Mach3 community.
« Reply #29 on: October 09, 2018, 01:56:02 PM »
I use the Homman Designs MB-02V6 and they are fine. Note they are TTL output, ie 5V. If you want 24V IO or optisolated or PWM
outputs then you will have to add your own circuitry. That exactly what I do, electronics is my thing, so its easy to do.
The CNC Room MB02 comes into its own if you don't want to add interface circuitry.
