Hello
Guest
it is
April 25, 2024, 12:00:16 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Velocity Units/Minute ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Velocity Units/Minute ? (Read 969 times)
gorf23
189
on:
September 30, 2018, 01:13:21 PM »
is there a formula to set Velocity Units/Minute.
in the machine.ini file shows maxvelocty I assume its the same value as Velocity Units/Minute in motor tuning
so if I change the Velocity Units/Minute to 80 the machine.ini file will change to 3600
so if I change the Velocity Units/Minute to 50 the machine.ini file will change to 2250
I am bad at math so I would like to know how mach4 calculates the values..
Thanks for any info
Gary
Logged
SwiftyJ
215
Re: Velocity Units/Minute ?
Reply #1 on:
September 30, 2018, 02:39:31 PM »
The velocity in the machine.ini file is in counts/second I think.
If you take your counts per unit for that motor, divide by 60, and then multiply by the velocity you want, you will get the velocity value in the machine.ini file
Logged
Print
Pages:
1
Go Up
« previous
next »
