Hello Guest it is March 28, 2024, 05:43:20 PM
Author Topic: Mach4 Spindle lag problems  (Read 1224 times)
« on: September 25, 2018, 06:09:36 AM »
Hi. I got a serious problem with my Mach4 Spindle.
Case:
Spindle are running, and 1 or more axis are moving But when all axis movement stops my spindle does an short halt. Not long, but I can see it on the spindle and
hear clicking noise from the servo spindle motor. If 2 axis are moving and 1 axis stops it's ok. It happens only when last axis stops. This happens both in manual
and G-code running mode. There is no difference whenether I move axis with external buttons or buttons onscreen.
I tested several orginal WX4 screensets, and are pretty sure this error must be in MAch4 Core or maybe some settings in my SmoothStepper ???
My machine setup are like this:
Mach4 (latest release)
ESS SmoothStepper
Pokeys 57U for external button panel
Spindle 1,8kw AC Servomotor
X and Y 750w AC Servomotor
Z 1,3kw AC Servomotor
A 200w AC Servomotor
PLC for lubrication, tool release and some safety stuff
Any suggestions anyone ? This is kinda gamebreaking.
Re: Mach4 Spindle lag problems
« Reply #1 on: September 25, 2018, 01:52:40 PM »
My spindle does the same thing.  I'm running an AC motor with a VFD and not a servo, but none the less, after I jog it will sometimes wind down for a fraction of a second and wind back up.
Also running the ESS
Chad Byrd
« Reply #2 on: September 25, 2018, 08:05:16 PM »
i use pokey cnc ,never have such problem
« Reply #3 on: September 25, 2018, 08:58:40 PM »
I didn't have this problem when I first started using Mach4 on this mill.  Don't know what changed.
I don't have this problem on any of my HiCON Integras.
Chad Byrd
