Hello Guest it is April 26, 2024, 06:58:36 PM
Author Topic: Spindle runs CCW when started manally  (Read 2138 times)
« on: September 23, 2018, 04:39:31 AM »
I have a rather odd problem running a spindle via a Huanyang VFD and a USB - RS485 com-port. I'm using Mach3 with the modbus plugin.
Everything works fine if I load G-Code and run it. The spindle turns on when it should and runs at the correct speed and in the correct direction.
If I start the spindle manually by first inputting an RPM and then pressing the screen-button it turns backward. My first thought was that I didn't make a setting somewhere but the problem is stranger. If I first start G-Code and press the stop button as soon as the spindle starts, I can then start it manually and it turns in the correct direction. If I change the speed, however, it reverts and turns backward again.
Any ideas? Thanks in advance,
DB
