Hello Guest it is April 26, 2024, 03:11:22 AM
Author Topic: configuring Fusion 360 to get rid of "k word given for arc in XY Plane"  (Read 2551 times)
Hi im super new to all of this but, ive got a simple pocket drawn in Fusion 360 and when I run the post process the Gcode it spits out gives me "k word given for arc in XY plane."  Im guessing MAch 4 can only do arcs in one plane at a time.  So does anyone know if there is a way to modify Fusion 360 so that the code given is only arcing in one plane at a time?
thanks in advance,
Offline Stuart
  •  311 311
Re: configuring Fusion 360 to get rid of "k word given for arc in XY Plane"
« Reply #1 on: September 21, 2018, 01:46:20 AM »
Ask on the fusion forum for problems with fusion 360 , it’s not a mach4 one
Offline thosj
  •  532 532
« Reply #2 on: September 21, 2018, 08:52:36 AM »
The X/Y plane IS one plane, isn't it?
Tom
« Reply #3 on: September 21, 2018, 08:57:16 AM »
Yes it is.  I guess my guestion should have been, Has anyone set up fusion 360 so that the output is compatible with Mach 4?  and in response to the first reply, I am asking there too.  This isn't a problem with anything its simply a configuration problem specific to MACH 4 and Fusion.
« Reply #4 on: September 21, 2018, 09:14:28 AM »
I just figured it out, I think.... My ramp was set at "helix" and im thinking Mach 4 doesn't support that kind of plunging.
Offline Stuart
  •  311 311
« Reply #5 on: September 21, 2018, 10:12:45 AM »
Just make sure you use th lasted the post and put in your personal post folder
http://cam.autodesk.com/posts/
Just type in Mach4
« Reply #6 on: September 21, 2018, 12:51:04 PM »
Just type in Mach4
That did it,  I had it in there but forgot to select it!! I knew it was going to be a bonehead mistake
« Reply #7 on: September 22, 2018, 07:12:28 AM »
FYI Mach3 and Mach4 both support helical ramping.
I use them all the time.
Mike.
« Reply #8 on: October 01, 2018, 03:29:23 PM »
Mike.
Yeah I had the wrong post selected!!
