Hello Guest it is April 26, 2024, 07:32:28 AM
Author Topic: Mach 4 sometimes disables the servos when regenerating tool path  (Read 1147 times)
« on: September 12, 2018, 01:57:19 PM »
This has happened several times recently. I don't know if this is a Plugin issue with the ESS or whether it's an issue with Mach4. Perhaps this is somehow related to a watchdog not being refreshed during the regeneration?
Re: Mach 4 sometimes disables the servos when regenerating tool path
« Reply #1 on: September 25, 2018, 07:28:05 AM »
I am also facing this same issue. Dont know why so. Is it fixed or is it still persisting. Help is appreciated.
Thanks in advance.
Shane.
« Reply #2 on: September 25, 2018, 03:48:46 PM »
My guess is that it's an ESS problem. I've posted my log on the Warp9TD forum where it disabled following a load file/display toolpath event, so hopefully that will provide clues.
I think the ESS momentarily disables the drive occasionally but not long enough to latch it permanently off. During that time, pulses are still being output so they're lost and you end up with an offset. This is my speculation, but it fits nicely with the fact that there is definitely a problem with random disable events and sometimes a loss of position.
